0
Offline
Jr. Member
Arduino rocks
« on: September 21, 2011, 06:24:08 pm » |
How do you zero pad an integer in the Arduino IDE? Say X can be 0 to 100, and I want to display X as a 3 digit number i.e. 1 = 001.
Logged
Central MN, USA
Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
« Reply #1 on: September 21, 2011, 06:38:48 pm » |
Where do you want the number displayed? On serial monitor, LCD? Below is pseudo code. You need to replace the print with whatever output device you use. if (number<100) print('0'); if (number<10) print('0'); print(number;
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #2 on: September 21, 2011, 09:03:10 pm » |
Sorry about that, the serial monitor and a LCD. So the only way to do that is with a if statement, there isn't a built in way to do it? I am working with two number and at times one might be greater than 100 and the other might be less than 100.
Logged
Southern California
Offline
Sr. Member
I like blinky lights
« Reply #3 on: September 21, 2011, 09:16:47 pm » |
printf("%03d", number);
If you need to send it to both the serial port and a LCD, use sprintf() to print it to a string, then print that string to both outputs.
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #4 on: September 21, 2011, 09:32:30 pm » |
Thanks Chris, sprintf() might be the way to go because I am also using the NewSoftSerial library.
Logged
Central MN, USA
Offline
Faraday Member
« Reply #5 on: September 21, 2011, 10:45:02 pm » |
That's my choice any day of the week but I didn't know how much OP wants to learn a C function  I visit this site every time I forget how to use all the nice features of sprintf: http://www.cplusplus.com/reference/clibrary/cstdio/sprintf/If you do "%3d" then you get space padding to the left.
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #6 on: September 22, 2011, 08:07:31 am » |
Thanks for the link liudr. Is sprintf library dependant, I didn't get a chance to test it out last night?
Logged
Central MN, USA
Offline
Faraday Member
« Reply #7 on: September 22, 2011, 08:31:46 am » |
With sprintf in the blink example code, it compiles just fine without using any library. I think the library is already included by arduino by default.
Logged
New Hampshire
Offline
God Member
There are 10 kinds of people, those who know binary, and those who don't.
« Reply #8 on: September 22, 2011, 10:12:39 am » |
That is correct, though in a somewhat circuitous manner. main.cpp include WProgram.h (the sketch you create is automatically merged with main.cpp by the Arduino IDE) WProgram includes from the AVR Libc library: http://www.nongnu.org/avr-libc/user-manual/group__avr__stdlib.htmlhttp://www.nongnu.org/avr-libc/user-manual/group__avr__string.htmlhttp://www.nongnu.org/avr-libc/user-manual/group__avr__math.htmlBut also includes from the 'Arduino library', among other things, HardwareSerial.h HardwareSerial.h includes Stream.h Stream.h includes Print.h And Print.h includes http://www.nongnu.org/avr-libc/user-manual/group__avr__stdio.html, which provides the various versions of printf. It's all rather academic from the perspective of being able to use sprintf(), but it never hurts to have an understanding of what's going on beneath the covers, and I think it's always useful to know that the variety of C library functions in those modules are available for your usage within Arduino sketches by default.
Logged
Central MN, USA
Offline
Faraday Member
« Reply #9 on: September 22, 2011, 10:46:44 am » |
That is pretty complicated  . I can certain appreciate a breakdown of what happens and hope the OP gets it too. I have been including stdio.h but I'll remove it now that a version of it is already included.
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #10 on: September 22, 2011, 02:39:50 pm » |
I totally undestand. Thanks for the breakdown jraskell. I'm going to try sprintf out when I get home.
Logged
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #11 on: September 22, 2011, 02:44:15 pm » |
and I think it's always useful to know that the variety of C library functions in those modules are available for your usage within Arduino sketches by default. Could be useful to have a list of functions avalible that don't require an include directive? Lefty
Logged
Offline
Newbie
« Reply #12 on: February 09, 2013, 12:15:04 am » |
Here is example code for using sprintf() to print formatted integers and dtostrf() for floats that works: (not very elegant, but then neither is C, esp for printing.) /* Print padded (aligned) integers and floats from Arduino environment * sprintf() for integers www.cplusplus.com/reference/cstdio/printf/ * and dtostrf() for floats dtostrf(FLOAT,WIDTH,PRECSISION,BUFFER); gist.github.com/2343665 www.nongnu.org/avr-libc/user-manual/group__avr__stdlib.html#g6c140bdd3b9bd740a1490137317caa44 */
int n; int m; byte i = 1; float x; char c[10]; // long enough to hold complete integer string char f[10]; // long enough to hold complete floating string
void setup() { randomSeed(1); Serial.begin(57600); }
void loop() { n = random(-1000,1000); // generate a random integer x = n/1000.0; // convert to a float <= |1.0|
m = sprintf(c, " %3d: %5d ", i,n); // build integer string using C integer formatters (m is length, and not used in this code) Serial.print(c);
dtostrf(x,6,3,f); // -n.nnn Use this for a consistent float format Serial.println(f); i++; delay(1000); }
Output: 1: -193 -0.193 2: 249 0.249 3: -927 -0.927 4: 658 0.658 5: -70 -0.070 6: 272 0.272 7: 544 0.544 8: -122 -0.122 9: 923 0.923 10: 709 0.709 11: -560 -0.560 12: -835 -0.835
Logged
UK
Offline
Tesla Member
« Reply #13 on: February 09, 2013, 10:18:59 am » |
That might be a moving target - I don't suppose the Arduino development team consider that the set of implicitly-included headers for any given library or for the environment as a whole is parts of the defined interface for that library or environment. (Microsoft don't either; they're always changing things around and breaking code that took the implicit includes for granted.)
Logged
