Topic: RISING and FALLING interrupt on same pin? (Read 10026 times) previous topic - next topic
ArduinoTom
Can I use a single pin to tigger a RISING interrupt service routine, as well as a separate FALLING interrupt service routine?
JChristensen
Use a pin change interrupt, or INT0 and INT1 can both be configured to interrupt on any logical change. Looks like it will be up to the code to determine rising or falling, but that should be straightforward. Read the pin first thing in the ISR, if it's low, then falling, if high then rising. So one ISR rather than two, but the same functionality can be accomplished I think.
DuaneB
Thats badically it, the external interrupts int0 and int1 which are on digital pins 2 and 3 can be set to interrupt on rising, falling or change which is the one you want.
For the other interrupts its a little more difficult, but there is a library that helps. here is a quick overview of the library 'pinchaneint'
http://rcarduino.blogspot.com/2012/03/need-more-interrupts-to-read-more.html
Duane B
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
nickgammon
The pin change interrupt isn't going to help any more than doing a CHANGE interrupt would. In any case, there is only one ISR.
Conceivably you could switch from RISING to FALLING inside the ISR, but why bother? By the time you have done that, you may as well have found out (by reading the pin) which one it is.
robtillaart
  pinMode(pin, OUTPUT);
  attachInterrupt(0, isr, CHANGE);
  digitalWrite(pin, state);
void isr()
  if (digitalRead(2) == HIGH) doRising();  // you can use direct port read to be faster - http://www.arduino.cc/en/Reference/PortManipulation -
  else doFalling();
doRising()
doFalling()
Rob Tillaart
InlineSkater
#5
Jan 23, 2016, 09:01 pm Last Edit: Jan 23, 2016, 09:10 pm by InlineSkater
I realised a routine for starting an exposure timer, which has a single start button at INT1 and the same button should be used to store permanently the selected time (set by a rotary encoder on the remaining pin INT0) into the EEPROM for further usage, if found worthwhile.
Depending on the duration time the button is pressed, different actions will start accordingly. During these activities the interrupts are temporarily blocked from being interrupted by other interrupts.
Here is what I did to swap interrupt modes within different but corresponding ISRs. I hope it may help a bit.
Have fun...
InlineSkater ;)
| Question: Can we have an ISR on one pin with different reaction   |
| modes set? Answer: Yes, we can...                                 |
| Successfully tested with Arduino Nano in breadboard testbed       |
| Author   : InlineSkater                                           |
| Date     : 23.01.2016 20:30:28                                    |
| Revision : 1.0                                                    |
| Switch goes low at Pin 3: checked bei ISR, indicated by red LED   |
| ISR mode change realised within two corresponging ISRs to detect  |
| falling & subsequent rising edge of start pulse. Short & long     |
| pulse discriminated and corresponding action started.             |
#define DEBUG
#define REDLED 13
#define BUTTON 3
long unsigned int startTime;
long unsigned int stopTime;
int delta_time;
int delta_store = 600;
int delta_start = 50;
#ifdef DEBUG
  Serial.println(">>> button_test4 >>>");
  while(!Serial) {
    // wait here for established serial connection
#endif
  pinMode(BUTTON, INPUT);
  digitalWrite(BUTTON, HIGH);
  pinMode(REDLED, OUTPUT);
  digitalWrite(REDLED, HIGH);
  attachInterrupt(INT1, button_low_isr, FALLING);
  delta_time = stopTime - startTime;
    if (delta_time >= delta_store) {      // was it a short/long duration?
#ifdef DEBUG
      Serial.println("ACTION 1");
#endif
      action0_task();                    // it was a long duration pulse
      if (delta_time >= delta_start) {
#ifdef DEBUG
        Serial.println("ACTION 0");
#endif
        action1_task();                  // it was a short duration pulse
void action0_task() {        // store display time into EEPROM
  noInterrupts();            // as a semaphore: no ISR allowed
  // action code here: store digits with no interruption
  interrupts();
void action1_task() {        // start display time count down
  // action code here: start timer with no interruption
  interrupts();
void button_low_isr() {      // 1st action: button goes low and we see it
  digitalWrite(REDLED, LOW);
  startTime = millis();      // time shall be noted & mode changed
  attachInterrupt(INT1, button_high_isr, RISING);
void button_high_isr() {    // 2nd action: button goes high and we see it
  stopTime = millis();      // time shall be noted & mode changed
