Loading...
Pages: [1]   Go Down
Author Topic: 74HC595 troubles  (Read 677 times)
Croatia
Offline Offline
Full Member
View Profile
I just started messing with shift registers and started off with http://arduino.cc/en/Reference/shiftOut http://arduino.cc/en/Tutorial/ShiftOut and few other web pages google came up with.
Currently I have single 74HC595 hooked up to an Uno, just the way it is connected here, with one difference. I don't have a 0.1"f capacitor (I suppose that is 0.1μF?) at hand so I tried without it.
The problem manifests in the way that although all the LEDs function at some time, they don't always light up. For example, in my attempt to pinpoint the problem I dumbed down the code to count to 9, took out all the ifs and loops and fancy variables. It now looks like this:
Code:
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
  //set pins to output so you can control the shift register
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
      digitalWrite(latchPin, LOW);
    delay(1);
    shiftOut(dataPin, clockPin, MSBFIRST, 0);
    delay(1);
    digitalWrite(latchPin, HIGH);
   delay(1);
    shiftOut(dataPin, clockPin, MSBFIRST, 1);
    delay(1);
   delay(1);
    shiftOut(dataPin, clockPin, MSBFIRST, 2);
 delay(1);
   delay(1);
    shiftOut(dataPin, clockPin, MSBFIRST, 3);
  delay(1);
    delay(1);
    shiftOut(dataPin, clockPin, MSBFIRST, 4);
    delay(1);
      delay(1);
    shiftOut(dataPin, clockPin, MSBFIRST, 5);
    delay(1);
      delay(1);
    shiftOut(dataPin, clockPin, MSBFIRST, 6);
    delay(1);
      delay(1);
    shiftOut(dataPin, clockPin, MSBFIRST, 7);
    delay(1);
      delay(1);
    shiftOut(dataPin, clockPin, MSBFIRST, 8);
    delay(1);
      delay(1);
    shiftOut(dataPin, clockPin, MSBFIRST, 9);
    delay(1);
See? Can't be much dumber than this.
The code is supposed to light up the LEDs and represent the numbers in binary. However, it skips some numbers entirely. For example, after the number three which is represented with LEDs one and two, all LEDs turn off until it is time for number five (LEDs three and one). Six also doesn't work at all, but seven (first three diodes) happily glows correctly like nothing happened.
Working and non working numbers are randomly interchanging so every number eventually lights up at exactly the right time, showing that everything is hooked up correctly, that arduino is sending the numbers at the right time.
Could all this come from the lacking cap? I tried 10μF (the only one I had around) but the problem just changes slightly (half works for a bit just like before, then completely freezes until the cap is removed).
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Yes.
Logged
Cape Town South Africa
Offline Offline
Edison Member
A newbie with loads of posts, and still so much to learn !
View Profile
WWW
The only caps that should be on the board, are a 0.1mFd  ( 100nF ) across the vcc and ground pins of the chip, with prefrably a 10 mFD electrolytic across that.
There should be no cap on the latch pin ( we have been trying to get that removed in the tutorial )
Make sure your grounds are connected propertly between the 595 and the Arduino ground.
Logged
We live in the era of the smart phones and stupid people.
Croatia
Offline Offline
Full Member
View Profile
I'm not sure I understand this part. What is "that" you are referring to?
I suppose they are, considering all the LEDs light up eventually.
Logged
Croatia
Offline Offline
Full Member
View Profile
Got it to work. The problem was... well, let's call it user error smiley-lol.
Logged
Rhode Island - USA
Offline Offline
Full Member
View Profile
i'm about to start the same exact thing... i just got my 0.1uF 50V's in the mail today..
100 of them for $3.00 on ebay.... seller:thaishine
« Last Edit: February 11, 2013, 06:45:35 pm by Ruffsta » Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
I buy from here
Cheaper, and quicker delivery.
http://www.dipmicro.com/store/C5K10-50
or
http://www.taydaelectronics.com/capacitors/ceramic-disc-capacitors/10-x-0-1uf-50v-ceramic-disc-capacitor-pkg-of-10.html
e-bay often not the best choice, I rarely buy there.
« Last Edit: February 11, 2013, 06:57:52 pm by CrossRoads » Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Rhode Island - USA
Offline Offline
Full Member
View Profile
i normally would have ordered from dipmacro.. but i didn't see any uF's... i didn't know you could use nF's.. so i was looking for the specific ones..
i have also ordered from tayda... both are excellent and highly recommended sources!
for the most part, they are cheaper - but not in all instances..
ie:
100 Bright RGB LED 5mm Common Anode Clear Lense 4-pin Bulb Tri-Color's - dipmacro price: $19.94 + shipping - ebay price: $12.94 free shipping
that's just 1 example - overall yes, i would stick with dipmacro or tayda -but since i am not that much in a rush, waiting on delivery is ok at the moment with me.
« Last Edit: February 11, 2013, 07:37:34 pm by Ruffsta » Logged
Offline Offline
Newbie
View Profile
100nF is 0.1uF and its represented by a 104 on the side of most disk caps.
Logged
Rhode Island - USA
Offline Offline
Full Member
View Profile
not everybody knows that (especially new people to arduino).. uF and nF were 2 different things to me.. so i looked specifically for uF
Logged
Eugene, Oregon
Offline Offline
Sr. Member
View Profile
WWW
I often refer to them as 104 caps, that is often what is printed on the cap (even tiny smt ones)
Just be glad that you dont have to read color dots.
Logged
Cumming, Ga
Offline Offline
Edison Member
Ultimate DIY: Arduino
View Profile
WWW
An interesting electronics hobby anomaly I've noticed over the years.    Tinkerers in the USA tend to avoid the nano-farad nomenclature entirely.  Commonly skipping from micro-farad ranges like  0.47uF .047uF and then slip right into pico-farad ranges like 4700pF, 470pF and 47pF....   while the rest of the world seems quit at home with using the "mid-range" nano-farad which really does help with keeping the numbers manageable.
http://www.justradios.com/uFnFpF.html
Logged
Leeds, England
Offline Offline
Full Member
Quick, chuck it in the bin before the boss finds out...
View Profile
I find the use of centimetres odd. I can't immediately think of anything else where we use 'centi' in everyday measurement. Everything else is in powers of 103.
Logged
Pages: [1]   Go Up
Print
Jump to:
