Topic: SparksFun serial LCD Display and Due (Read 815 times) previous topic - next topic
EVP
I have tested this code successfully on the Ardunio Mega.
Code: [Select]
  Serial1.begin(9600);
  backlightOn();
  selectLineOne();
  Serial1.print(millis());
  selectLineTwo();
  Serial1.print(millis()/2);
  delay(100);
void selectLineOne(){  //puts the cursor at line 0 char 0.
   Serial1.write(0xFE);   //command flag
   Serial1.write(128);    //position
   delay(10);
void selectLineTwo(){  //puts the cursor at line 0 char 0.
   Serial1.write(192);    //position
   delay(10);
void goTo(int position) { //position = line 1: 0-15, line 2: 16-31, 31+ defaults back to 0
if (position<16){ Serial1.write(0xFE);   //command flag
              Serial1.write((position+128));    //position
}else if (position<32){Serial1.write(0xFE);   //command flag
              Serial1.write((position+48+128));    //position
} else { goTo(0); }
   delay(10);
void clearLCD(){
   Serial1.write(0x01);   //clear command.
   delay(10);
void backlightOn(){  //turns on the backlight
    Serial1.write(0x7C);   //command flag for backlight stuff
    Serial1.write(157);    //light level.
   delay(10);
void backlightOff(){  //turns off the backlight
    Serial1.write(128);     //light level for off.
   delay(10);
void serCommand(){   //a general function to call the command flag for issuing all other commands
However it doesn't seem to work on the Arduino Due. I get a serial signal but it's just junk text. I'm using a ttl level converter to go from 3.3 to 5. Is their a software reason?
Cheers.
EVP
I solved it, it needs a delay in the setup. That seemed to do it.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
