Topic: 7 Segment connection and code (Read 965 times) previous topic - next topic
zoom
Connected the middle pins both at the up and bottom to ground, a,b,c,d,e,f,g are connected to outputs as well. (didn't use any resistor for a,b,c... but GND)
The code is quite straightforward but didn't work don't know why ? At where am I wrong ?
int a = 8;
int b = 9;
int c = 10;
int d = 11;
int e = 12;
int f = 13;
int g = 7;
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(7, OUTPUT);
  digitalWrite(a, LOW);
zoom
#1
Feb 09, 2013, 02:06 pm Last Edit: Feb 09, 2013, 02:17 pm by zoom Reason: 1
Okay I've realised one of the problems.
pinMode declarations had to be as follows
pinMode(a, OUTPUT) and goes like that.
However, still nothing happens.
johnwasser
Did you try setting any of the output pins HIGH?
Are you sure your displays are Common Cathode?
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
zoom
Yes I've tried both High and low
floresta
Connected the middle pins both at the up and bottom to ground, ...
Maybe those are not the common pins.  You haven't told us anything about the display so we really can't tell.
Adequate for testing, but not a good solution.
Don
