Topic: Stepper Moves, IR Flashes, Repeat... How? (Read 5378 times) previous topic - next topic
IntelliTom
Hi
I am new to programming and have been through a lot of the basic beginner arduino tutorials.  I'm working on my first 'real' project.  What I need to do is set a stepper to turn X amount of steps, then fire and IR LED.  Then wait for X secs (while a camera takes a pic) and repeat for X number of moves (a full rotation).  I would also like a 'manual mode' where I press a button and it does one move and one IR flash.
Now I have a sketch working for the stepper and I have a sketch working for the IR flash (to camera).  My problem is combining the 2 sketches to make one synchronised routine.  As a beginner, I don't even know what to Google for.  I think in basic terms I need this to happen:
1. 'Start Button' is Pressed
2. IR Flashes/Camera Shoots
3. Wait for 2 secs for camera to process
4. Motor Turns 10 degrees
5. Wait 5 secs for motor to turn
6. IR Flashes/Camera Shoots
7. Then Loop 3, 4, 5 & 6  35 times.
8. Stop (maybe make a sound at stop).
I do want to learn this, but I'm stumped as to where to start.  The two sketches I have working are:
IR to Nikon - Example by LadyAda
int IRledPin =  13;    // LED connected to digital pin 13
void setup()   {
  pinMode(IRledPin, OUTPUT);
  SendNikonCode();
// This procedure sends a 38KHz pulse to the IRledPin
// for a certain # of microseconds. We'll use this whenever we need to send codes
void pulseIR(long microsecs) {
  // we'll count down from the number of microseconds we are told to wait
  cli();  // this turns off any background interrupts
  while (microsecs > 0) {
    // 38 kHz is about 13 microseconds high and 13 microseconds low
   digitalWrite(IRledPin, HIGH);  // this takes about 3 microseconds to happen
   delayMicroseconds(10);         // hang out for 10 microseconds, you can also change this to 9 if its not working
   digitalWrite(IRledPin, LOW);   // this also takes about 3 microseconds
   // so 26 microseconds altogether
   microsecs -= 26;
  sei();  // this turns them back on
void SendNikonCode() {
  pulseIR(2080);
  delay(27);
  pulseIR(440);
  delayMicroseconds(1500);
  pulseIR(460);
  delayMicroseconds(3440);
  pulseIR(480);
  delay(65); // wait 65 milliseconds before sending it again
  pulseIR(2000);
  delay(27);
  pulseIR(440);
  pulseIR(460);
  pulseIR(480);
Stepper - Example by LadyAda
#include <AFMotor.h>
AF_Stepper motor(200, 1);
  motor.setSpeed(5);  // 10 rpm
  Serial.println("Double coil steps");
  motor.step(6, FORWARD, DOUBLE);
If someone could just give me a clue as to which commands I need to be using or if my predicted routine is correct?
PaulS
You have two functioning sketches. You have no attempt to combine them. How do you know that you will not be successful?
In general, with two sketches that separately work, the thing that you need to do is to define what the requirements of the resulting code are to be. Then, you create a new sketch and borrow pieces from the two working sketches, and add some additional code, to meet the requirements for the combined sketch.
Remember that loop is called over and over in an infinite loop. If you want stuff to happen only now and then, such as when a switch is pressed, you need to add code to make that happen. If you want stuff to happen only a certain number of times, you must add code to make that happen.
IntelliTom
ok, sorry.  That makes sense and I have been hacking code together with little success.  I've just gone back over it line by line to see if I can understand what's going on.  Now I don't have the motor and motor shield here with me today, so I am relying on the serial monitor to give me a clue that stuff if happening.
This is what I currently have
void setup()   {
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Start!");
  motor.setSpeed(5);
  RotateTT();
   microsecs -= 26;
  Serial.println("Fire Camera!");
  pulseIR(2080);
  delay(27);
  pulseIR(440);
  pulseIR(460);
  pulseIR(480);
  pulseIR(2000);
  delay(27);
  pulseIR(440);
  pulseIR(460);
  pulseIR(480);
  delay(55);
void RotateTT() {
  Serial.println("6 Double coil steps");
The output that I get in the serial monitor is:
Start!
6 Double coil steps
The camera does not fire.
Any suggestions?
PaulS
Does the motor rotate? If so, look at what causes that to happen, and where that code is called.
There is no call to the function to fire the camera. If you do fire the camera, what will take the pictures in the future? You'll need to hire a replacement.
IanMcRV
#4
Feb 09, 2013, 08:50 pm Last Edit: Feb 09, 2013, 08:57 pm by IanMcRV Reason: 1
Hi IntelliTom.
Looks like you are almost there. I don't have the kit to fully test but this might help a bit.
So you can see in the Arduino sketch there are three main parts,
there's the part at the top where you can include other 'libraries' and you can initialize variables.
Then there is the void setup()   part and this part is usually used to set everything up, change the pinModes, etc.
Then there is the void loop() part and usually what happens in a sketch is that the code will be looping around in here waiting for things to happen and then reacting to those things.
So normally everything would be going on in the void loop() part where for example you might have a button set up and then when the user presses that button the program would turn the stepper motor to the required position and then when it was at the correct position it would fire the camera, then wait again for the motor to turn etc. then fire the camera again etc.
Here is an idea how to do it although you may need to adjust some things, have a play and see if you can get it to work, you can't break anything :)
int NumberOfPictures = 10;  // How many pictures should we take?
int CountVariable = 0;  // I'll use this to keep a tab on how many pictures we've taken so far.
void setup()   {
 motor.setSpeed(5);
if (CountVariable == NumberOfPictures) return; // Stop now as CountVariable indicates that we have taken the correct NumberOfPictures
RotateTT();
delay(500); // wait half a second for good measure
SendNikonCode();
CountVariable ++; // increment the count variable so it is actually counting :)
}  // at this point it will go to the top of the loop at the void loop() line and start again.
  microsecs -= 26;
 pulseIR(2080);
 delay(27);
 pulseIR(440);
 pulseIR(460);
 pulseIR(480);
 pulseIR(2000);
 delay(27);
 pulseIR(440);
 pulseIR(460);
 pulseIR(480);
 delay(55);
void RotateTT() {
IntelliTom
Hi Ian
Thanks for taking the time to help.  I have been playing with this all day ;)
A friend helped me and I got this working in a different way:
int IRledPin =  12;    // LED connected to digital pin 12
const int ButtonPin = 2;
int ButtonState = 0;
   microsecs -= 26;
  pulseIR(2080);
  delay(27);
  pulseIR(440);
  pulseIR(460);
  pulseIR(480);
  pulseIR(2000);
  delay(27);
  pulseIR(440);
  pulseIR(460);
  pulseIR(480);
  delay(55);
void RotateTT() {
// setup() is called first, then loop() is repeatedly called until power is switched off.
// We're doing everything in setup(), so loop() can be empty.
void setup()   {
  pinMode(ButtonPin, INPUT);
  motor.setSpeed(5);
  for (int i = 0; i < 5; i++) {
  if (ButtonState == LOW) {
     SendNikonCode();
     RotateTT();
  else {
  // All done. Loop here, doing nothing.
Though your method works too and seems cleaner.  However, the next step is as you suggested, a button to start the process.  I can't seem to work out the right code.  You can see in the example above what I have tried and it just acts like the button is not there.  i.e it cycles through the 2 functions for the amount specified, then stops.  I tried to add a button start to your code also and the same happens
int NumberOfPictures = 5;  // How many pictures should we take?
void setup()   {
  motor.setSpeed(5);
RotateTT();
delay(1000); // wait half a second for good measure
SendNikonCode();
   microsecs -= 26;
  pulseIR(2080);
  delay(27);
  pulseIR(440);
  pulseIR(460);
  pulseIR(480);
  pulseIR(2000);
  delay(27);
  pulseIR(440);
  pulseIR(460);
  pulseIR(480);
  delay(55);
void RotateTT() {
I would love to know what I'm doing wrong  :smiley-eek:
IntelliTom
ok I am a step closer.
int ButtonState = HIGH;
void setup()   {
  motor.setSpeed(5);
    Serial.println("Button Pressed");
  RotateTT();
  SendNikonCode();
   microsecs -= 26;
  pulseIR(2080);
  delay(27);
  pulseIR(440);
  pulseIR(460);
  pulseIR(480);
  pulseIR(2000);
  delay(27);
  pulseIR(440);
  pulseIR(460);
  pulseIR(480);
  delay(55);
void RotateTT() {
I changed the 'int ButtonState = 0;' to 'int ButtonState = HIGH;' and now I have it where in the serial monitor it prints 'Start!' and pauses.  But pressing the button does not do anything.  I've double checked the wiring and tested the button with a separate sketch.  My pin numbers are correct.
:smiley-sweat:
IanMcRV
#7
Feb 10, 2013, 01:21 am Last Edit: Feb 10, 2013, 01:23 am by IanMcRV Reason: 1
Hi Tom,
You need to set the pinMode to INPUT_PULLUP because otherwise you will get problems when using things like a stepper motor or a servo.
See if this works, all I'm doing here is first setting the counter to the max so nothing happens in the loop and then when the user presses the button it resets the counter to 0 so that the loop begins the processing.
Gets rid of enclosing everything in an if statement:
int CountVariable = 5;  // I'll use this to keep a tab on how many pictures we've taken so far. I've set this to 5 already so nothings going to happen until its reset to 0
int ButtonPin = 2; // needn't be a const
// int ButtonState = 0; // don't need this line
void setup()   {
 pinMode(ButtonPin, INPUT_PULLUP); // you hadn't set the pin mode in your example, you need to wire the button between pin 2 and Gnd
 motor.setSpeed(5);
// you also need to use digitalRead(ButtonPin) to get the value of the pin.
 if (digitalRead(ButtonPin) == LOW) CountVariable = 0; // the magic line, if the button is pressed then the count is set to 0 so it all begins.
RotateTT();
delay(1000); // 1000 milliseconds = 1 second
SendNikonCode();
// everything below this is nicely hidden away :)
  microsecs -= 26;
 pulseIR(2080);
 delay(27);
 pulseIR(440);
 pulseIR(460);
 pulseIR(480);
 pulseIR(2000);
 delay(27);
 pulseIR(440);
 pulseIR(460);
 pulseIR(480);
 delay(55);
void RotateTT() {
IntelliTom
Thanks Ian, but no joy.  This just cycles through the whole thing endlessly.  Doesn't stop at 5, doesn't wait for a button press.
IanMcRV
#9
Feb 10, 2013, 01:43 am Last Edit: Feb 10, 2013, 01:47 am by IanMcRV Reason: 1
Ah, okay,  I was doing it from memory. It's late here. I'll have a go tomorrow and do some testing on my system. Sorry it doesn't work yet but I think we're close!
One thing though. Try using pin 3 for the button instead of pin 2 as pin 2 is the main serial port.
PaulS
No, it isn't. Pins 0 and 1 are.
OP: You have Serial.begin() and Serial.println() in setup(), but no Serial.print() or Serial.println() statements in loop. Why not? Add a Serial.println() statement to tell you when the switch is pressed. (Also tell us how the switch is wired). Add Serial.print() and Serial.println() statements to output what CountVariable and NumberOfPictures are. (Work on that name, too. Of course CountVariable is a variable. That part of the name tells you nothing. Of course, CountVariable is being used to count something. But, there is no clue as to what is being counted. A name like NumberOfPhotosTaken would be better, in my opinion. It's quite clear what that is counting.)
IanMcRV
#11
Feb 10, 2013, 05:51 pm Last Edit: Feb 10, 2013, 05:54 pm by IanMcRV Reason: 1
Oh yeah  :smiley-red:
Absolutely right PaulS.
Lets get the basics up and running first, here's a sketch that I did actually try out on my Arduino :)
int ledPin =  13;    // LED connected to digital pin 13 You will need to change this.
int NumberOfPicturesTaken = 5;  // I'll use this to keep a tab on how many pictures we've taken so far. I've set this to 5 already so nothings going to happen until its reset to 0
int ButtonPin = 3; // you'll need to change this.
void setup()   {
 pinMode(ledPin, OUTPUT);
 if (digitalRead(ButtonPin) == LOW) NumberOfPicturesTaken = 0; // the magic line, if the button is pressed then the count is set to 0 so it all begins.
 if (NumberOfPicturesTaken >= NumberOfPictures) return; // Stop now as NumberOfPicturesTaken indicates that we have taken the correct NumberOfPictures
 NumberOfPicturesTaken ++;
 Serial.print("NOPT = ");
 Serial.println(NumberOfPicturesTaken);
 digitalWrite(ledPin, HIGH);
 digitalWrite(ledPin, LOW);
IntelliTom
HI Ian
Sorry for the delay in replying, life has a habit of getting in the way.
I have loaded your code onto the arduino.  The serial monitor prints 'Start!' then cycles 'NOPT = 1' endlessly.  If I press the button and hold it, the Serial monitor prints 'NOPT = 1' then 2, 3, 4 & 5 and then stops.  When I release the button it continues to cycle NOPT = 1 endlessly
It's late here and I'm not firing on all cylinders, what was the goal of this code?  Just to show the button press?  It seems to be working in reverse of what I need.  The code need to wait for a single press of the button and then cycle through the specified number of pictures/routines.
I'll spend some more time on this tomorrow.  Thanks for taking the time to help
IanMcRV
Hi Tom, that's weird.
Can you post your code please.
(worked on mine).
PeterH
This code is intended to reset the count when the button input state is LOW.
It seems that your input is wired differently, so that the input is normally LOW and goes HIGH when you press the button. Given that the software enables the internal pullup resistor, you must have overridden this with another external pull-down resistor. You can either rewire your switch so it reads HIGH in the normal position and LOW when it is pressed, or change the LOW to HIGH in the code above.
(Changing the code would be easier, but IMO it would be better to lose the external pull-down resistor and change the switch wiring so that the switch connects the pin to ground when it is closed.)
