Topic: [SOLVED] Random LED's (Read 3416 times) previous topic - next topic
Mubanga
Feb 09, 2013, 03:43 pm Last Edit: Feb 10, 2013, 03:35 pm by Mubanga Reason: 1
Say I have 9 LED's connected to my arduino on pin 1 to 9. I want to be able to let a certain number of LED's go on, but which of the LED's go on has to be random. Any thoughts?
johnwasser
I wouldn't use Pin 1 (Serial TX) for I/O since Serial.print() is so helpful for debugging.
I'd use an array of N pin numbers.  Pick some pairs of random numbers between 0 and N-1.  Swap those two elements of the array to shuffle the array.  Go through the array from 0 to N-1 turning on the desired number of LEDs and turning off the rest.
robtillaart
pseudo code
for (int i=0; i<9; i++)
  if (random(2) == 1) led[i] on
  else led[i] off
Rob Tillaart
johnwasser
pseudo code
  else led[i] off
That will turn on a random combination of the 9 LEDs but will not "let a certain number of LED's go on, but which of the LED's go on has to be random."  By that I assume they meant that the number of lights turned on is known but the pattern is random.  That's why I recommended the shuffle.
Mubanga
That's right, I didn't fully understand your first post though but so far I've got this:
int timer = 1000; //Sets timer
int ledPins [] = {2, 3, 4, 5, 6, 7,}; //Sets pins
int pinCount = 6; //Sets the number of pins
int Number = 3; //Sets the amount of LEDs that will go on
int thisPin; //Specificies a certain pin
  for (int thisPin = 0; thisPin < pinCount; thisPin++) {
    pinMode(ledPins[thisPin], OUTPUT); //Sets all the ledPins as output
void loop(){
  for (int i=0; i<=Number; i++){
  if (i < Number) {
  thisPin = random(pinCount);
  digitalWrite(ledPins[thisPin], HIGH); }  //this will loop "Number" times
  else {
  delay(timer);
  digitalWrite(ledPins[thisPin], LOW); } //turns of all the pins
this almost works except sometimes there will be only 1 or 2 light burning instead of 3, because the pin has already been picked.
Grumpy_Mike
So instead of just picking a random number and using it you pick a random number and if it has already been chosen pick another one. A wile loop can be used to ensure that it only exits when a number not chosen before has been selected.
This is oddly prescriptive, is it homework?
Mubanga
Thanks!
No not at all, I just picked up Arduino as a hobby and I'm trying to rebuild a binary clock I saw a while back.
legendlcox
you need to set a random value like in this sketch.
#include <LiquidCrystal.h>
int address;
long randomvalue = 0; //random balue 1
long countervalue = 0; // counter value
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
  lcd.begin(16,2);
  lcd.print("COX Industries");
  countervalue = 1;
  lcd.setCursor(0,0);
  lcd.print("------START-----");
  lcd.setCursor(0,1);
  lcd.print("--CALCULATION---");
  delay(1500);
  lcd.clear();
  lcd.setCursor(0,0);
  randomvalue = random(1000000000);
  lcd.print(countervalue);
  lcd.setCursor(4,1);
  lcd.print(randomvalue);
  lcd.clear();
  countervalue = (countervalue+1)%1000000;// increment the counter
Grumpy_Mike
And how is that going to stop there being a repeat number in any batch of random numbers?
johnwasser
So instead of just picking a random number and using it you pick a random number and if it has already been chosen pick another one. A while loop can be used to ensure that it only exits when a number not chosen before has been selected.
Like this:
const int ledPins [] = {
const int pinCount = 6; //Sets the number of pins
int thisPin;
int alreadySet;
void loop(){
  // Turn off all the LEDs
  // Turn on "Number" randonm LEDs
  for (int i=0; i<Number; i++) {
    do {
      alreadySet = digitalRead(ledPins[thisPin]);
    while (alreadySet);  // If the LED was already on, try a different one
  delay(timer);
Mubanga
#10
Feb 09, 2013, 06:40 pm Last Edit: Feb 09, 2013, 06:42 pm by Mubanga Reason: 1
Thanks John! Although this way I won't be able to use shift registers won't I? because in my final project I will be using 27 LED's. But that's not to big of a problem, in that case I will use I2C I/O expanders.
PaulS
How does a clock use random numbers?
JimboZA
Well, I was just reading this Instructable about someone whose sleep pattern might be better suited to 6x sleeps a week not the traditional 7..... maybe others would be happier on time system which wakes them up and sends them to bad randomly.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Mubanga
Like this!
http://www.youtube.com/watch?v=Vu0geKPNs4E
johnwasser
You can use an unsigned long (32-bit integer) to keep track of which LEDs you want on and off.
unsigned long pattern;
int thisPin;
int alreadySet;
void loop(){
  pattern = 0;
    do {
      alreadySet = pattern & (1<<thisPin));
      pattern |= (1<<thisPin);
  //  Send 'pattern' to shift registers
  delay(timer);
[/quote]
