Topic: Get the push button sense once (Read 951 times) previous topic - next topic
zoom
I'm using the push button with the built in pull-up resistor;
pinMode(b1, INPUT_PULLUP);
and have such a main loop. Whenever I press the push button and hold, the empty string called "pass" takes dozens of "1", as expected :)
However I want to make it sense the push once until I release it and push again.
By that structure, it is not likely to implement I think.
What would your suggestions be ?
  if(digitalRead(b1) == LOW)
    pass += "1";
    counter += 1;
robtillaart
You must make a variable that holds the state of the button. Only if the state changes there is action
something like this
int pressed = 0;
  if (digitalRead(b1) == LOW && pressed == 0)
    pressed = 1;
    pass += "1";
    counter++;
  if (digitalRead(b1) == HIGH && pressed == 1)
    pressed = 0;
give it a try
Rob Tillaart
zoom
Seems pretty logical but doesn't work.
I've implemented more or less a similar solution but it didn't work either. Strange
something like this
int pressed = 0;
    pressed = 1;
    pass += "1";
    counter++;
    pressed = 0;
give it a try
UKHeliBob
This code does what I would expect
String pass;
int counter =0;
int pressed = 0;
int b1 = 3;
    pressed = 1;
    pass += "1";
    counter++;
    Serial.println(pass);
    pressed = 0;
Sample output of 4 button presses
1
11
111
1111
NOTE - no debounce implemented but the button action seems relatively snappy so not a problem
zoom
1
11
111
at 1 press. Very snappy :/
What can I do ?
UKHeliBob
Debounce the button by the look of it.
HazardsMind
And maybe look for a button state change.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
