Topic: Help Understanding Code: processInput (Read 670 times) previous topic - next topic
mech_eng
void processNumber (int x)
  switch (whichNumber)
  case CASE:
    Casev = x;
    whichNumber = Speed;
    break;
  case Speed:
    Speedv = x;
    whichNumber = CASE;
    break;
void processInput ()
  static int receivedNumber = 0;
  static boolean False = false;
  byte c = Serial.read ();
  switch (c)
  case EOP:
    if (False)
      processNumber (- receivedNumber);
      processNumber (receivedNumber);
    // fall through to start a new number
  case SOP:
    receivedNumber = 0;
    False = false;
    break;
  case '0' ... '9':
    receivedNumber *= 10;           // receivedNumber = recievedNumber*10 increments decimal places
    receivedNumber += c -'0';      //receivedNumber = recievedNumber + (c - '0') goes from char to decimal
    break;
  case '-':           // What is this for?
    False = true;
    break;
I have enough grasp on this code to use it but it bugs me that I do not fully understand it.
Is processInput a special function in the Arduino language?
What is the case '-' for? Does this just keep the received number positive?
robtillaart
this code has definitely style issues
False is the var that shows if a number is negative
CASE is also a bad name as it is a reserved word in C/C++
EOP is a EndOfPacket
SOP is a StartOfPacket
processInput reads an char from serial and builds up a number. If end of packet is received the number is processed.
And what that does is a mystery if we cannot see all the code.
Rob Tillaart
johncc
I remember seeing this code when you posted it before because the variable name just cracks me up :)
  case CASE:
    Casev = x;
    break;
  case Speed:
    Speedv = x;
    whichNumber = CASE;
    break;
  switch (c)
  case EOP:
    if (False)
  case SOP:
    receivedNumber = 0;
    False = false;
    break;
  case '0' ... '9':
    break;
    False = true;
    break;
processInput is not "Arduino language", it is defined right there in your code.
It examines the current character coming in, and if it is a '-', it takes note that the number that follows should be a negative number.  If the variable were named "isNegativeNumber", it would be clearer.
seealso http://arduino.cc/forum/index.php/topic,145379.msg1092845.html#msg1092845
PeterH
No, this is just a piece of code that somebody has written.
The case '-' is executed when the byte returned by Serial.read() contains the ascii character '-' (a minus sign).
Google for "C++ switch case".
I only provide help via the forum - please do not contact me for private consultancy.
mech_eng
thanks all, cleared some things up for me
