I remember seeing this code when you posted it before because the variable name just cracks me up
void processNumber (int x)
switch (whichNumber)
case CASE:
Casev = x;
whichNumber = Speed;
break;
case Speed:
Speedv = x;
whichNumber = CASE;
break;
void processInput ()
static int receivedNumber = 0;
static boolean False = false;
byte c = Serial.read ();
switch (c)
case EOP:
if (False)
processNumber (- receivedNumber);
processNumber (receivedNumber);
// fall through to start a new number
case SOP:
receivedNumber = 0;
False = false;
break;
case '0' ... '9':
receivedNumber *= 10; // receivedNumber = recievedNumber*10 increments decimal places
receivedNumber += c -'0'; //receivedNumber = recievedNumber + (c - '0') goes from char to decimal
break;
case '-': // What is this for?
False = true;
break;
I have enough grasp on this code to use it but it bugs me that I do not fully understand it.
Is processInput a special function in the Arduino language?
What is the case '-' for? Does this just keep the received number positive?
processInput is not "Arduino language", it is defined right there in your code.
It examines the current character coming in, and if it is a '-', it takes note that the number that follows should be a negative number. If the variable were named "isNegativeNumber", it would be clearer.
seealso
http://arduino.cc/forum/index.php/topic,145379.msg1092845.html#msg1092845
