Author Topic: E-licktronic Libraries  (Read 417 times)
E-licktronic design a simple electronic solution for you to build your own midi/audio hardware
Two libraries to use E-licktronic module
SRIO library allow you to use shift register very easily http://www.e-licktronic.com/en/content/19-tutorial-library-srio
And PotMUX library allow you to use multiplexing pot as simple as Arduino language http://www.e-licktronic.com/en/content/23-tutorial-potmux-library
Dallas
Shannon Member
This Connection is Untrusted
You have asked Firefox to connect securely to www.e-licktronic.com, but we can't confirm that your connection is secure.
Normally, when you try to connect securely, sites will present trusted identification to prove that you are going to the right place. However, this site's identity can't be verified.
Probably be a good idea to fix the SSL certificate.
Thank you for the information we are working on.
