Loading...
Pages: [1]   Go Down
Author Topic: Uno shows up in Win device manager - but not in IDE  (Read 413 times)
Nashua, NH
Offline Offline
Newbie
http://www.bradgoodman.com/
View Profile
WWW
I have this problem ALL the time on TWO different Windows 7 machine, with two different Unos.
It works for a while - but if it's "interrupted" (like I unplug the Uno, then re-plug it in) - get gets into this funny state where, even though the Device Manager sees the Uno going aways and comming back (on the SAME COM port) - the IDE no longer sees it.
Even if I quit and restart the IDE, it STILL does not recognize it. Eventually, it does recognize it. (No idea when/why). Rebooting the machine seems to do this. I am *positive* that I am actually shutting down and restarting the IDE.
Any idea why this is happening - or better yet - how to get through it?
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
If an application (e.g. Serial Monitor) has a USB-serial port (e.g. your Uno) open and the USB-serial port is removed ("surprise removal" in USB vernacular), Windows gets rather testy.  Usually, shutting down the application, disconnecting the USB device, then reconnecting the USB device clears the problem.
Logged
Nashua, NH
Offline Offline
Newbie
View Profile
WWW
Right - problem is, it doesn't  smiley-confuse
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
"Does not recognize it"?  Please provide details.
Logged
Nashua, NH
Offline Offline
Newbie
View Profile
WWW
UNO's COM port does not show up in the "Serial Ports" menu, despite showing up in Device Manager.
If you are on a system in which it is the only COM port, the "Serial Ports" menu is greyed-out (ie there are no ports to be listed).
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
I suspect a faulty cable or hub.
Logged
Chile
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Can you send a snapshot of how it looks in the device manager?
Logged
My homepage/blog: http://erwin.ried.cl
Nashua, NH
Offline Offline
Newbie
View Profile
WWW
Not a cable or hub. Two different boards, cables, computers.
Will send snapshot of Device Manager - but all is good there. Arduino app should show ANY com port there, but doesn't. I can't be the only one with this problem!
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
I have Windows 7 / 64 bit on this computer, frequently connect / disconnect my Uno when changing hardware, and have never had to reboot the computer because of an Uno related problem.
When the problem occurs, is an instance of avrdude running?
Logged
Nashua, NH
Offline Offline
Newbie
View Profile
WWW
I don't know. (What is that?) Should I check and make sure it's not running in Task Manager?
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Exactly.  When the failure occurs look for avrdude in Task Manager.
Logged
Offline Offline
Newbie
View Profile
Hi..
I had the exact same issue. The device manager showed the comports, but it did not appear in the arduino IDE.
My situation was that I tried to read some data through Processing from an Arduino Uno and an Arduino Pro Mini. I was using a USB hub to read the data from both devices. There were couple of times the processing ran into Null Pointer Exceptions and some other errors while reading the data. After that I started getting the issue. Also sometimes the both devices didn't detect well when I used the hub.
Solutions : I disabled the comport for the Uno on the Device Manager. Then enabled it again and it worked ok. Also, using a hub did not work robustly for the two Arduino's. I used two different USB ports on my laptop and it worked well (but it worked well with one Arduino and other devices like mouse and keyboard on the USB hub)
Sometimes you get this error when you try to read the Serial Data from another program (like Processing in my case) and crashes. I think this is because the Serial Port is not released by that program when the error occurs. So try everything possible to make sure the port is released to run it again.
Hope this helps smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
