Topic: Uno shows up in Win device manager - but not in IDE (Read 3207 times) previous topic - next topic
bkgoodman
I have this problem ALL the time on TWO different Windows 7 machine, with two different Unos.
It works for a while - but if it's "interrupted" (like I unplug the Uno, then re-plug it in) - get gets into this funny state where, even though the Device Manager sees the Uno going aways and comming back (on the SAME COM port) - the IDE no longer sees it.
Even if I quit and restart the IDE, it STILL does not recognize it. Eventually, it does recognize it. (No idea when/why). Rebooting the machine seems to do this. I am *positive* that I am actually shutting down and restarting the IDE.
Any idea why this is happening - or better yet - how to get through it?
Coding Badly
If an application (e.g. Serial Monitor) has a USB-serial port (e.g. your Uno) open and the USB-serial port is removed ("surprise removal" in USB vernacular), Windows gets rather testy.  Usually, shutting down the application, disconnecting the USB device, then reconnecting the USB device clears the problem.
bkgoodman
Right - problem is, it doesn't  :~
Coding Badly
"Does not recognize it"?  Please provide details.
bkgoodman
UNO's COM port does not show up in the "Serial Ports" menu, despite showing up in Device Manager.
If you are on a system in which it is the only COM port, the "Serial Ports" menu is greyed-out (ie there are no ports to be listed).
Coding Badly
eried
Can you send a snapshot of how it looks in the device manager?
My website: http://ried.cl
bkgoodman
Not a cable or hub. Two different boards, cables, computers.
Will send snapshot of Device Manager - but all is good there. Arduino app should show ANY com port there, but doesn't. I can't be the only one with this problem!
Coding Badly
I have Windows 7 / 64 bit on this computer, frequently connect / disconnect my Uno when changing hardware, and have never had to reboot the computer because of an Uno related problem.
When the problem occurs, is an instance of avrdude running?
bkgoodman
I don't know. (What is that?) Should I check and make sure it's not running in Task Manager?
Coding Badly
Exactly.  When the failure occurs look for avrdude in Task Manager.
roshan82
Hi..
I had the exact same issue. The device manager showed the comports, but it did not appear in the arduino IDE.
My situation was that I tried to read some data through Processing from an Arduino Uno and an Arduino Pro Mini. I was using a USB hub to read the data from both devices. There were couple of times the processing ran into Null Pointer Exceptions and some other errors while reading the data. After that I started getting the issue. Also sometimes the both devices didn't detect well when I used the hub.
Solutions : I disabled the comport for the Uno on the Device Manager. Then enabled it again and it worked ok. Also, using a hub did not work robustly for the two Arduino's. I used two different USB ports on my laptop and it worked well (but it worked well with one Arduino and other devices like mouse and keyboard on the USB hub)
Sometimes you get this error when you try to read the Serial Data from another program (like Processing in my case) and crashes. I think this is because the Serial Port is not released by that program when the error occurs. So try everything possible to make sure the port is released to run it again.
Hope this helps :)
