Topic: MAX6959 and I2C (Read 2234 times) previous topic - next topic
ichris93
Feb 09, 2013, 09:28 pm Last Edit: Feb 09, 2013, 10:32 pm by ichris93 Reason: 1
Hello all,
I am working on a project which requires a four digit seven segment display which is connected to my Arduino with a MAX6959 that interfaces with I2C.  I can get all of the segments to light up with the following display test code.
#include <Wire.h>
 Wire.begin();
 Wire.beginTransmission(0b0111000);
 Wire.write(0x07);
 Wire.write(0x01);
 Wire.endTransmission();
But I can't figure out how to control the digits.  Here is a link to the data sheet, http://datasheets.maximintegrated.com/en/ds/MAX6958-MAX6959.pdf
Thanks!
pylon
You can use the following code to set the value of every digit:
byte d[] = { 0x7e, 0x60, 0x6d, 0x79, 0x33, 0x5b, 0x1f, 0x70, 0x7f, 0x7b };
void set_digit(byte digit, byte value) {
  Wire.beginTransmission(0x38);
  Wire.write(0x20 + digit);
  Wire.write(d[value]);
ichris93
I probably have the code setup wrong.  But bellow is what I have and it isn't working.  Thank you for your help.
#include <Wire.h>
  Wire.begin(); // join i2c bus (address optional for master)
{Wire.beginTransmission(0x38);
set_digit(0, 0);
PaulS
The code does something. You haven't described that.
You want the code to do something. How that differs from what it does isn't clear.
The ball's back in your court.
ichris93
#4
Feb 11, 2013, 12:12 am Last Edit: Feb 11, 2013, 12:23 am by ichris93 Reason: 1
When I send it that code, the display doesn't show anything.  When I send it that code I would like it to display 0 on digit 0.
pylon
You should have tried with another digit, because digit 0 is in decode mode by default. Insert the following into your setup routine:
Wire.write(0x01); // register decode mode
Wire.write(0x00); // disable decode mode for all digits
A short description what the set_digit() routine does:
// array holding the bitsets for displaying digits 0 to 9
// see page 9, figure 10 of the datasheet for the segment numbering
  Wire.beginTransmission(0x38); // address the MAX6959
  Wire.write(0x20 + digit); // register 0x20 is digit 0, 0x21 is digit 1, etc.
  Wire.write(d[value]); // write the value from the array to the register.
ichris93
Even with the following code, nothing happens.  What am I doing wrong?
#include <Wire.h>
  Wire.begin();
  Wire.write((uint8_t)0x00); // disable decode mode for all digits
  set_digit(3, 1);
pylon
Let's extend setup to be sure that all registers have a valid content:
  Wire.begin();
  Wire.write(0x3f); // intensity max
  Wire.write(0x03); // scan limit 3
  Wire.write(0x03); // normal operation
ichris93
#8
Feb 11, 2013, 02:34 am Last Edit: Feb 11, 2013, 02:37 am by ichris93 Reason: 1
 Wire.begin();
Great!! Thank you! That finally has it working.  BUT you have 0X60 for 1 and it should be 0X30 and for 6 you have 0X1F and it should be 0X5F.
