(USA)
« on: February 09, 2013, 04:55:16 pm » |
Hello,
I was wondering what would happen if I pulled more amps from a wall wart then it was rated for.
Thanks!
Dubuque, Iowa, USA
« Reply #1 on: February 09, 2013, 05:38:27 pm » |
Depends. If you pull more amps from a wall wart than it's rated for then you should wear Depends.
Could be anything from switching off until replugged-in, blowing a fuse, or creating a fire.
« Reply #2 on: February 09, 2013, 05:53:47 pm » |
The latter outcome should not happen if its a genuine UL-certified part (and not a cheap knock-off). A general purpose PSU is more likely to be built to take abuse than one designed for a single piece of equipment I suspect.
(USA)
« Reply #3 on: February 09, 2013, 06:11:09 pm » |
The fire is what i'm afraid of. It is ul listed. It came from a Router and is rated for 1 amp. Do you think 2amps would cause a fire?
Thanks, Drew
« Reply #4 on: February 09, 2013, 06:28:37 pm » |
Do you think 2amps would cause a fire? What anyone thinks is irrelevant. The supply is rated for 1 amp. Don't exceed that. Period. Pete
(USA)
« Reply #5 on: February 09, 2013, 06:38:21 pm » |
I'm not trying to exceed the 1amp rating, but it is being used to power a motor and if the motor stalls it might hit 2 amps before my fuse breaks! Would a few seconds at 2amps cause a fire?
Thanks, Drew
Boston area, metrowest
Online
« Reply #6 on: February 09, 2013, 06:39:35 pm » |
If its a "switching" regulator, it will likely just shut down. (small & compact design) If its a linear regulator, the output will start dropping as the current goes past 1A and it starts getting hot to the point of failure/fire. (larger, blockier design)
(USA)
« Reply #7 on: February 09, 2013, 06:50:21 pm » |
Are the "switching" regulators light compared to the linear regulators? Also It is newer. Does that matter with which one it is?
Thanks!
Online
« Reply #8 on: February 09, 2013, 07:11:17 pm » |
Yes, switching are light compared to linear - no big bulky transformer inside.
"Does it matter which one?"
Yes: If its a "switching" regulator, it will likely just shut down. If its a linear regulator, the output will start dropping as the current goes past 1A and it starts getting hot to the point of failure/fire.
(USA)
« Reply #9 on: February 09, 2013, 07:19:21 pm » |
I think I have a linear regulator. I will just buy a wall wart online that will meat the Specs I need.
Just out of curiosity do they have a capacitor in them because it seems that it holds it's charge a good while after its been unplugged.
Thanks for all the help!
« Reply #10 on: February 09, 2013, 07:35:04 pm » |
I would doubt any certified wall wart would catch on fire if the output is dead shorted. I would think that any device with "user accessable" electrical contacts would be designed with the expectation that the user will sooner or later short the contacts.
(USA)
« Reply #11 on: February 09, 2013, 07:57:07 pm » |
If I end up going with the wall wart I have, should the fuse be placed on the positive wire or the negative one?
Thanks!
Left Coast, CA (USA)
Measurement changes behavior
« Reply #12 on: February 09, 2013, 07:58:39 pm » |
Thanks!
Makes no difference, the same current flows through both wires. The convention is to put it on the positive, if the circuit it powers uses a negative common. Lefty
Online
« Reply #13 on: February 09, 2013, 08:00:15 pm » |
(USA)
« Reply #14 on: February 09, 2013, 08:04:53 pm » |
Thanks for the help everybody!
