Loading...
Pages: 1 [2]   Go Down
Author Topic: Battery choice/source help?  (Read 501 times)
Australia
Offline Offline
Full Member
View Profile
Mostly correct.
A batteries capacity , in this case 110 mah , is rated at a particular discharge rate, and its usually 0.1C , but LIPOs are better, hence in this case 0.2C.
This means that if you discharge the battery at 0.2C,  22 ma it will take 5 hours to discharge the battery.
If however , you discharge the battery at 2C, 220 ma, the battery will be discharged in less than 30 minutes.
The differance is made up because of the fact that the battery heats up when discharged at a high rate,
so the heat energy is lost , and not available as electrical output.
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
ok..thanks..  (glad Im finally grasping it a bit more)  LOL..
to continue on now.. (looking for a solution)
then this battery would work? (LIR2450)
http://www.megabatteries.com/item_details2.asp?id=14443&sid=shopgoogle&gclid=CLvPzunjqrUCFfBDMgodKV8AyA
http://www.powerstream.com/p/Lir2450.pdf
but 'same' battery linked to here.. says MAX DISCHARGE is only 35mA?
http://www.batteryspace.com/li-ionrechargeable2450buttoncellstwolr245036v120mah24dx5tmm043wheach.aspx
how can a noob like myself be sure?  (or am I mixed up again?)  lol
(not that these need to be rechargable or anything.. just looking for a 'fit')
thanks!
Logged
Australia
Offline Offline
Full Member
View Profile
No, those batteries wont work as they arnt LIPO, but most likley Lithium Ion manganese.
Coin type cells dont have hi discharge capability, as they arnt designed for that type of purpose.
Forget using Coin type batteries.
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
ok..
so is this datasheet just 'bs' then?
or am I reading it wrong/missing something?
(even though now I understand forget about coin cell.. I am just curious as its still confusing compared to other (same) pieces of data, in other datasheets/websites I have seen/we've been reviewing)..
thanks.
Logged
Australia
Offline Offline
Full Member
View Profile
You would have to try one and see.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
