Topic: Servo motor question (Read 2759 times) previous topic - next topic
Serge_Brien
Hello,
  My idea is to construct a kart and I already saw some motors that would probably allow me to do so.
  However, they are usually very expensive..
  While I was searching, I found this motor that has a very high torque but at the same time it's cheap, comparing to the other motors (DC) I saw. Am I missing something? is it because, despite having such an high-torque, it's a  bit slow and more suitable to other applications..
http://www.ebay.co.uk/itm/12V-24V-6-8A-320KG-CM-High-power-High-torque-Servos-Driver-Full-Metal-Robot-/121055540092?pt=UK_BOI_Industrial_Automation_Control_ET&hash=item1c2f78f37c
  Thanks in advanced !
larryd
It is probably surplus.
Supply and demand.
For example there are lots of these available:
http://www.princessauto.com/pal/product/8366429/Miscellaneous-Surplus/Window-Crank-Motor
OR
http://www.surplustraders.net/category/DC%20GEARHEAD%20MOTORS-0184
No technical PMs.
The last thing you did is where you should start looking.
Serge_Brien
Thanks LarryD ! It makes sense.
Would you advise me to use it ? This car/kart will have to be able to climb ramps with a considerable inclination.
larryd
Do you need to use a servo motor or will a DC gear motor do?
You have to come up with some numbers and design criteria:
Speed
Weight
Incline
Forward/Reverse/Steering
Amperage/Voltage you will be using
Remote control
etc.
No technical PMs.
JimboZA
You'll need to do the physics to answer that.... mass, slope (wth is "considerable"?), velocity, acceleration, wheel diameter and other gearing aspects, force, torque etc etc. Mechanics 101.....
Edit... Looks like LarryD and I are thinking along the same lines....
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Serge_Brien
That's my main doubt at the moment. What would be the main advantages in this case of using a servo, instead of a gear dc motor?
I already did some calculations, with these values: Speed - 10km/h (6mph); Weight - 150kg (330lbs); COF - 10º to 30º; Direction - it has to move in both directions; be able to control the speed of the motor; wheel diameter - 250mm (9.85 inches); each motor must have at least 250 Watts
I didn't present these values earlier, because initially I just want to try to control the motor direction and speed with a joystick(or playstation remote) that I have. If I'm successful in controlling the direction and speed of 2 motors , I will continue from there..
