Loading...
Pages: [1]   Go Down
Author Topic: what does this mean 'val is not declared in this scope'?  (Read 205 times)
india
Offline Offline
Newbie
View Profile
Code:
#include <Servo.h>
// Controlling a servo position using a potentiometer (variable resistor)
// by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
#include <Servo.h>
Servo myservo1;  // create servo object to control a servo
Servo myservo2;
Servo myservo3;
Servo myservo4;
int potpin1 = 0;  // analog pin used to connect the potentiometer
int potpin2 = 1;
int potpin3 = 2;
int potpin4 = 3;
int val1;    // variable to read the value from the analog pin
int val2;
int val3;
int val4;
  myservo1.attach(3);  // attaches the servo on pin 9 to the servo object
  myservo1.attach(5);
  myservo1.attach(6);
  myservo1.attach(9);
  val1 = analogRead(potpin1);            // reads the value of the potentiometer (value between 0 and 1023)
  (it comes here)
  val1 = map(val, 0, 1023, 0, 179);      // scale it to use it with the servo (value between 0 and 180)
  myservo1.write(val);                   // sets the servo position according to the scaled value
  delay(15);                             // waits for the servo to get there
  val2 = analogRead(potpin2);            // reads the value of the potentiometer (value between 0 and 1023)
  val2 = map(val, 0, 1023, 0, 179);      // scale it to use it with the servo (value between 0 and 180)
  delay(15);
  val3 = analogRead(potpin3);            // reads the value of the potentiometer (value between 0 and 1023)
  val3 = map(val, 0, 1023, 0, 179);      // scale it to use it with the servo (value between 0 and 180)
  delay(15);
  val4 = analogRead(potpin4);            // reads the value of the potentiometer (value between 0 and 1023)
  val4 = map(val, 0, 1023, 0, 179);      // scale it to use it with the servo (value between 0 and 180)
  delay(15);
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Code:
val1 = map(VAL, 0, 1023, 0, 179);
I added the capitals for emphasis....You mean val1?
Each of those map lines refers to val, but I guess they should be val1, val2 etc
« Last Edit: February 10, 2013, 03:16:24 am by JimboZA » Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
East Anglia (UK)
Offline Offline
Edison Member
May all of your blinks be without delay
View Profile
Variables have a scope, ie a place or places where they are valid to use.  Global variables declared outside of a function at the top of the code, such as val1 etc in your code, are valid to use anywhere in the program.  Variables declared inside a function are only valid to be used within that function.  I can't see any of those in your program.
Either way they have to be declared (made known to the program before they are used).  The variable val in your program is not declared anywhere, hence the error message.
Incidentally, there is a missing right curly bracket in you code too but that may be the result of you copy/pasting it and missing it from the selection.
Logged
Ontario, Ohio
Offline Offline
Full Member
View Profile
Code:
(it comes here)
Delete that second line or make it a comment. Also you have imported the servo library twice.
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
I think the "it comes here" was an edit to point out where the error referred to, which was the "val" as opposed to the required "val1" on the next line.
Logged
IT Crowd:
Pages: [1]   Go Up
Print
Jump to:
