Topic: Help with some programming!! (Read 6499 times) previous topic - next topic
kurtselva
Hi guys,
I am doing a automatic feeder where the user inputs 3 information in a LCD display using 2 pushbuttons. and a food container will rotate at the specified timing using a servo motor.
The 3 info are: feeding interval per day, number of days to feed and time of 1st feed.
I have done the program to make the inputs increase to the required values for each info and am able to switch between the different info.
Now, I want to make the servo motor rotate at the specified timing interval when all the inputs have been inputted (i.e, the cursor is set to 7). From my code, the servo rotates at the specified interval but how do I make it stop after the specified days has been reached? By right, if the inputted feeding interval is 2, the interval will be every 12hr. But for testing purpose, I have made it to be 12sec interval. So what should I change my code so that, lets say the days to be fed is 2, then only 4 rotations of the motor at 12 sec interval is acheived and the motor does not rotate after that?
kurtselva
#1
Feb 10, 2013, 11:13 am Last Edit: Feb 10, 2013, 04:40 pm by kurtselva Reason: 1
Below is my code: in 2 seperate posts due to word limit exceeded
#include <LiquidCrystal.h>                // Include libraries
#include <Servo.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);    // initialize the library with the numbers of the interface pins
Servo myservo;
const int  incrementPin = 6;              // the pin that the increment pushbutton is attached to
const int  setPin = 7;                    // the pin that the set pushbutton is attached to
int incrementPushButtonState = 0;                        // state of the increment pushbutton (low or high)
int setPushButtonState = 0;                              //  state of the set pushbutton
int setCounter = 0;                                      // no. of times set button is puched
int feedinterval = 1;                                    // feedinterval counter range 2-4
int numberofdays = 0;                                    // no. of days counter range 1-10
int firsthourvalue = 0;                                  // first hour value range 1-2
int secondhourvalue = 0;                                 // second hour value range 0-9
int firstminutevalue = 0;                                // first minute value range 1-5
int secondminutevalue = 0;                               // second minute value range 0-9
int servoposition = 0;                                   // position of servo
 pinMode(incrementPin, INPUT);    // initialize the button pin as a input:
 pinMode(setPin, INPUT);
 myservo.attach(9);               // attaches the servo on pin 9 to the servo object
 lcd.begin(20,4);                 // LCD has 20 columns, 4 rows
 lcd.setCursor(0,0);              // Choose column 0, row 0( 1st column, 1st row)
 lcd.print("Freq:     Days:");    // Print the stated
 lcd.setCursor(0, 1);             // Choose column 0, row 1
 lcd.print("1st feed time:");     // Print the stated
 lcd.setCursor (0, 2);            // Choose column 0, row 2
 lcd.print("current time:");      // Print the stated
 lcd.setCursor(0,3);              // Choose column 0, row 3
 lcd.print("");                   // Print the stated
 lcd.setCursor(16,1);             // Choose column 16, row 2
 lcd.print(":");                  // Print the stated
  setPushButtonState = digitalRead(setPin);            // read the set pushbutton input pin:
    if (setPushButtonState == HIGH)                    // if the pushbutton is pressed, high
      if (setCounter > 6)                              // if pushbutton pressed more than 6 times, rollover to 0
        setCounter = 0;
      setCounter++;                                    // counter increment by 1
      if (setCounter == 1)                             // if counter is 1,
        lcd.setCursor(5,0);                             // set LCD to column 5, row 0 and
        lcd.blink();                                    // cursor blink
       if (setCounter == 2)                             // if counter is 2, blink cursor at stated position
       lcd.setCursor(15,0);
       lcd.blink();
       if (setCounter == 3)                              // if counter is 3, blink cursor at stated position
       lcd.setCursor(14,1);
       lcd.blink();
       if (setCounter == 4)                                // if counter is 4, blink cursor at stated position
       lcd.setCursor(15,1);
       lcd.blink();
       if (setCounter == 5)                                  // if counter is 5, blink cursor at stated position
       lcd.setCursor(17,1);
       lcd.blink();
       if (setCounter == 6)                                  // if counter is 6, blink cursor at stated position
       lcd.setCursor(18,1);
       lcd.blink();
       if (setCounter == 7)                                  // if counter is 7, blinking stops
       lcd.noBlink();
      delay (1000);
      if (setCounter == 1)                                        // if set counter is 1
        incrementPushButtonState = digitalRead (incrementPin);    //read increment push button from increment pin
      if (incrementPushButtonState == HIGH)                       // if push button is pressed (high)
        lcd.setCursor (5,0);                                     // set at 5th column, 0th row
        lcd.blink();
        feedinterval++;                                          // feed interval increases by 1
        lcd.print(feedinterval);                                 // print value of freq
        if (feedinterval > 4)                                    // if freq value more than 4, reset to 2
          feedinterval = 2;
        delay(300);
    else if (setCounter == 2)                                    // if set counter is 2
    incrementPushButtonState = digitalRead (incrementPin);      //perform same actions as for setCounter == 1
        lcd.setCursor (15,0);                                   // set at 15th column, 0th row
        lcd.blink();
        numberofdays++;
        lcd.print(numberofdays);                                 // print value of freq
        if (numberofdays > 10)                                    // if freq value more than 10, reset to 1
          lcd.print ("  ");                                        // clears lcd character and specified position
          numberofdays = 1;
        delay(300);
kurtselva
else if (setCounter == 3)                                          // if set counter is 3
         lcd.setCursor (14,1);                                       // set at 14th column, 1st row
         lcd.blink();
         firsthourvalue++;
         lcd.print(firsthourvalue);                                 // print value of freq
         if (firsthourvalue > 2)                                    // if freq value more than 2, reset to 1
           firsthourvalue = 0;
         delay(300);
    else if (setCounter == 4)                                         // if set counter is 4
         lcd.setCursor (15,1);                                       // set at 15th column, 1st row
         lcd.blink();
         secondhourvalue++;
         lcd.print(secondhourvalue);                                 // print value of freq
         if (secondhourvalue > 9)                                    // if freq value more than 9, reset to 0
           lcd.print ("  ");
         delay(300);
     else if (setCounter == 5)                                           // if set counter is 5
         lcd.setCursor (17,1);                                         // set at 17th column, 1st row
         lcd.blink();
         firstminutevalue++;
         lcd.print(firstminutevalue);                                 // print value of freq
         if (firstminutevalue > 5)                                    // if freq value more than 5, reset to 0
         delay(300);
     else if (setCounter == 6)                                           // if set counter is 6
         lcd.setCursor (18,1);                                          // set at 18th column, 1st row
         lcd.blink();
         secondminutevalue++;
         lcd.print(secondminutevalue);                                 // print value of freq
         if (secondminutevalue > 9)                                    // if freq value more than 9, reset to 0
           lcd.print("  ");                                            // clears lcd character at specified position
         delay(300);
     else if (setCounter == 7)
     if (feedinterval == 2)
     for (int j = 0; j <= numberofdays; j++)
       servo();
       delay (12000);
void servo()
  for (int i= 0; i < 1; i ++)
  for(servoposition = 0; servoposition < 180; servoposition += 1)        // goes from 0 degrees to 180 degrees
  {        // in steps of 1 degree
    myservo.write(servoposition);                                        // tell servo to go to position in variable 'pos'
    delay(15);                                                           // waits 15ms for the servo to reach the position
  for(servoposition = 180; servoposition>=1; servoposition-=1)           // goes from 180 degrees to 0 degrees
UKHeliBob
Not answering your question, but when I was looking at your code I saw this
How many times will this loop execute ?
How many times should it execute ?
kurtselva
It executes once: that is it goes from 0 degrees to 180 degrees and back to 0 degrees
UKHeliBob
So why the need for the loop at all ?
kurtselva
Hmm goood qn..
I copied it from the example sketch for servo  :D
UKHeliBob
Now back to your question about stopping the servo movement after it has done it a specified number of times.
You know how many times it should move, so when you move the servo add 1 to a counter, but before you move the servo check that the total number of required moves has not already taken place.  If it has then don't move the servo.
kurtselva
Ok, if you notice, I did just that in my code(See the last part where there is the int j)..
And I put the condition as j = numberofdays..
But it doesn't not work...And I can't identify the problem..
       servo();
       delay (12000);
PaulS
Properly
indented
code
is
much
easier
to
read.
Complete
code
is
essential.
Describing
what
the
code
actually
does
is,
too.
kurtselva
Complete
code
is
essential.
Describing
what
the
code
actually
does
is,
too.
Look at my first 3 posts
PaulS
Wouldn't a switch statement make more sense? Wouldn't some functions help?
Why can't you use Tools + Auto Format to indent the code properly? Why didn't you attach the code instead of spreading t across multiple posts?
What exactly IS the code doing? How does that differ from what you want?
UKHeliBob
As Paul asked, you need to tell us what is not working.
The servo() function appears to be called once for each day that feeding is needed (numberofdays) and is called twice each day, but only if setCounter is 7
          servo();
          delay (12000);
This is in the loop() function so, if nothing happens to stop it the next time through loop() it will happen all over again.  This is the reason that I suggested you keep a count of how many times the servo had moved and stop it happening once the required number of moves has taken place.
PaulS
Alternatively, set setCounter back to 0 once the servo movement is done.
kurtselva
Ok let me explain the code better:
user enters the following information using pushbuttons into a LCD display:
1) Feedinterval; this sets the interval between each feed and ranges from 2 -4. So if 2 is entered, then feed interval will be 12 hrly, 3 - 8hrly and 4 - 6 hrly
2) number of days for the feeding to continue. ranges from 1 to 10. SO if 2 is entered, then feeding will go one for 2 days etc
3) timefor first feed (this part will only come into play after I have worked on the existing problem)
So lets have a scenario: user inputs feedinterval= 2 and numberofdays = 2:
The servo will rotate a total of 2 times per day; so 4 times for 2 days..
For testing purpose, I cant wait for 12 hr interval. So I am testing with 12 sec interval instead.
SO the problem is I am not able to stop the servo from rotating even after the condition stated in the for loop has been satisfied..
