Topic: analog reference (Read 5218 times) previous topic - next topic
rbangar30
hello all,
I am using atmega328(without arduino,but programmed using arduino) in my project where in I am checking input from sensor on analog pin.
if it is HIGH necessary action is taken.
But even when no input is given by sensor,atmega shows HIGH signal.
Is this related to analog reference?
JimboZA
It's probably just noise, and you need a pull-down to force it low.... Just because a pin isn't deliberately high, doesn't mean it's actually low.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
rbangar30
Actually I am getting HIGH when it should return LOW.
fungus
hello all,
What sensor, what circuit, what code? My crystal ball isn't working today.
Very unlikely.
JimboZA
But how do you know it should be low?- when it's not getting any input there's no way of telling what it "should" be.
As fungus says, post more detail....
rbangar30
I am doing this as my college project.
I am using sim900 module along with PIR sensor.
    val1 = digitalRead(inputPin1); // read input value from PIR
    if (val1 == HIGH) { // check if the input is HIGH
      mySerial.print("ATD +919*********;");//dial the number
      delay(100);
      mySerial.println();
  else {
now this code calls me even when nothing is detected by PIR.
And for power,I am using 3.7V battery.
Grumpy_Mike
Why all the talk of analogue reference when all you are doing is a digital read?
Have you measured the input on the pin you are using?
You need to post ALL the code so we can see what you are doing.
Then you should have access to test equipment.
nickgammon
I should point out that loop is executed thousands of times a second, so you are going to be dialing that number an awful lot.
rbangar30
How if condition will be satisfied every time?
AWOL
Which PIR?
Where is your code?
Grumpy_Mike
Yes if you hold down the button for say one second it will be executed about 1000 times.
All it does is check if the button is down, it does not check that it has just gone down. In other words it checks for a level not an edge.
You need to read this:-
http://www.thebox.myzen.co.uk/Tutorial/Inputs.html
rbangar30
I tried example given at http://playground.arduino.cc/Code/PIRsense where in inbuilt pull up is used.
But still i am getting continues calls.
AWOL
...and we're still waiting for details of the PIR.
nickgammon
Post your new code.
Did you address what I said in reply #7?
