Topic: single potentiometer lock system (value not ignored as it ought to be) help plz (Read 738 times) previous topic - next topic
Eddiexyx2
this was supposed to be the code for a single potentiometer lock system but i keep getting the error "value not ignored as it ought to be" and since im still new at using the arduino and programming in in genaral i dont know what to do. Could anyone plz give me some tips on changes i should make to the code.
int r1 = A0;
int r2 = A1;
int button = 6;
int led1 = 13;
int led2 = 12;
int led3 = 11;
  pinMode(button,INPUT);
  pinMode(led1,OUTPUT);
  pinMode(led2,OUTPUT);
  pinMode(led3,OUTPUT);
int val1 = analogRead(r1);
  if(val1 == 598 && digitalRead(button) == HIGH) Serial.println( "acess1 clear")
  && digitalWrite(led1,HIGH);
  if(val1 == 450 && digitalRead(button) == HIGH && digitalWrite(led1,HIGH))
  Serial.println( "acess2 clear") && digitalWrite(led2,HIGH);
  if(val1 == 1023 && digitalRead(button) == HIGH && digitalWrite(led2,HIGH))
  Serial.println( "acess granted") && digitalWrite(led3,HIGH) ;
   Serial.println(val1);
johnwasser
You seem to be confused about the proper use of the Logical And (&&) operator.  I think this is what you might have intended:
  if(val1 == 598 && digitalRead(button) == HIGH) {
    Serial.println( "acess1 clear");
  if(val1 == 450 && digitalRead(button) == HIGH) {
    Serial.println( "acess2 clear");
    digitalWrite(led2, HIGH);
  if(val1 == 1023 && digitalRead(button) == HIGH) {
    Serial.println( "acess granted");
    digitalWrite(led3,HIGH);
You got the error because you tried to AND the result of digitalWrite() into an expression.  Since digitalWrite() returns a void value (no value) it can't be use in an expression.
