Pages: [1] 2   Go Down
Author Topic: ps2 barcode scanner using instantly  (Read 410 times)
Hi there, i am running this playground well http://playground.arduino.cc/ComponentLib/BarcodeScanner but i want make one change.
In the code as you see,  dataRead();  command always running in loop() .  I want to run it when i want. But it doesn't work.
Seattle, WA USA
Seattle, WA USA
And how is the Arduino supposed to know when that is?
We've hired a psychic who will be able to determine what the code actually does without seeing it, and how that differs from what you want, without you having to describe that.
His start date is the 12th of never. If you need help before then, there are some things you need to do.
Here this point is not important maybe? Why not when i click a button wired to one of digital pins?
 smiley
The code is this http://playground.arduino.cc/uploads/ComponentLib/arduino-barcode-code.txt
I just want to make run what have written in loop function  (i.e. when i click a button) in the code above.
I tried but it didn't work.
Here the code in the loop
dataValue = dataRead();
// If there is a break code, skip the next byte
if (dataValue == SCAN_BREAK) {
breakActive = 1;
// Translate the scan codes to numbers
// If there is a match, store it to the buffer
for (int i = 0; i < quantityCodes; i++) {
byte temp = scanCodes[i];
if(temp == dataValue){
if(!breakActive == 1){
buffer[bufferPos] = characters[i];
bufferPos++;
//Serial.print('*'); // Output an asterix for every byte
// Print the buffer if SCAN_ENTER is pressed.
if(dataValue == SCAN_ENTER){
Serial.print("\nbuffer: ");
// Read the buffer
int  i=0;                 if (buffer[i] != 0) {
while(buffer[i] != 0) {
Serial.print( buffer[i] );
buffer[i] = 0;
i++;
Serial.println(" [Enter]");
bufferPos = 0;
// Blink the LED
digitalWrite(ledPin, HIGH);
delay(300);
digitalWrite(ledPin, LOW);
// Reset the SCAN_BREAK state if the byte was a normal one
if(dataValue != SCAN_BREAK){
breakActive = 0;
dataValue = 0;
and dataRead() function
int dataRead() {
byte val = 0;
// Skip start state and start bit
while (digitalRead(clockPin));  // Wait for LOW.
// clock is high when idle
while (!digitalRead(clockPin)); // Wait for HIGH.
for (int offset = 0; offset < 8; offset++) {
val |= digitalRead(dataPin) << offset; // Add to byte
// Skipping parity and stop bits down here.
return val;
Now as you see, program always reading scanner data. But i want to check it like this way:
if(number==5)
checkBarcode();
void checkBarcode(){
breakActive = 1;
bufferPos++;
// Read the buffer
buffer[i] = 0;
i++;
bufferPos = 0;
// Blink the LED
delay(300);
breakActive = 0;
dataValue = 0;
UK
So check it that way then. What's the problem exactly? It looks to me like you've just posted the solution to your own original question.
no, i don't know where is the problem but code not working in this way.
East Anglia (UK)
May all of your blinks be without delay
If you have written the code that reads a barcode when a button is pressed but it does not work please post it here with a description of what it does.  In your skeleton code explaining what you want to do we do not know where the value of number comes from.
I am using u8glib libraly with one 128x64 graphic lcd. This libraly working like this code in the loop()
void loop(void) {
  // picture loop
  u8g.firstPage();
  do {
    draw();
  } while( u8g.nextPage() );
  // rebuild the picture after some delay
  delay(100);
//run barcode scanner
if(number==5)
checkBarcode();
checked=true;
void draw(void) {
  // graphic commands to redraw the complete screen should be placed here
  u8g.setFont(u8g_font_unifont);
  u8g.drawStr( 0, 20, "Hello World!");
//if barcode scanner had checked write ok.
  if(checked)
  u8g.drawStr( 0, 40, "ok checked");
In my setup, screen freezing when number=5
« Last Edit: February 11, 2013, 05:02:07 am by feveran » Logged
UK
Try here first, paying attention to section 6.
East Anglia (UK)
void loop(void) {
  // picture loop
  u8g.firstPage();
  do {
    draw();
  delay(100);
if(number==5)
checkBarcode();
checked=true;
void draw(void) {
  if(checked)
I try to be polite here, but which part of
did you not understand ?
Ok very thanks and many sorry to all. Here's coming the full code.
#include "U8glib.h"
U8GLIB_ST7920_128X64 u8g(9, 8, 3, U8G_PIN_NONE);
int barkod[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
 int SCAN_ENTER = 0x5a; int SCAN_BREAK = 0xf0;
int breakActive = 0;
int clockPin = 22; //
int dataPin = 19; //
int clockValue = 0; byte dataValue;
byte scanCodes[10] = {0x45,0x16,0x1e,0x26,0x25,0x2e,0x36,0x3d,0x3e,0x46}; char characters[10] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9'};
int quantityCodes = 10;
char buffer[64] = {}; // This saves the characters (for now only numbers)
int bufferPos = 0;
int bufferLength = 64;
bool barbool=false;
String inputString = "";         // a string to hold incoming data
boolean stringComplete = false;  // whether the string is complete
int number=0;
void setup(void) {
    // initialize serial:
  // reserve 200 bytes for the inputString:
  inputString.reserve(200);
             pinMode(dataPin, INPUT);
pinMode(clockPin, INPUT);
  void loop(void) {
  // picture loop
  u8g.firstPage();
  do {
    draw();
if(number==5)
checkBarcode();
//checked=true;
breakActive = 1;
bufferPos++;
// Read the buffer
int i=0;
buffer[i] = 0;
i++;
barbool=true;
bufferPos = 0;
// Blink the LED
breakActive = 0;
dataValue = 0;
void draw(void) {
  if(barbool)
int dataRead() {
byte val = 0;
return val;
void serialEvent() {
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inChar == 'a') {
      number = 5;
        if (inChar == 'b') {
      number = 1;
    Serial.println(number);
And the problem is this, when i send 'a' to the arduino (so number being set to 5, i can see it via serial port viewer)  screen freeze. When screen frozen if i use barcode scanner and make it scan a valid barcode code, screen blinks for 0.5 second (not exactly) then be frozen again.
Seattle, WA USA
Seattle, WA USA
If you worked for me, this would get you some time off. ONE statement per line!
Use the space bar to make the code readable. Also feel free to break that array initialization code onto more than one line. 2 groups of 5 is much easier to count than one group of 10.
This would too. Strings have major problems on the Arduino, and are a crutch, anyway.
This part says that you have an idea how big the static array should be. Go with that!
Comments after the code look pretty stupid. Comments BEFORE the code are a good idea.
if(number==5)
checkBarcode();
//checked=true;
Why
only
when
number
is
five?
What's
magic
about
five?
How
does
number
get
to
be
five?
I give up on the rest of that mess. The indentation is horrid. Put each { on a new line, and use Tools + Auto Format AND some comments if you really want help.
East Anglia (UK)
How
does
number
get
to
be
five?
In the serialEvent() function maybe ?
Does the capitalisation of the function name matter ?
//libraly for lcd screen
#include "U8glib.h"
//variables for barcod scanner
int clockValue = 0;
byte dataValue;
char buffer[64] = {
int bufferPos = 0;
//a state shows some job has done by barcode scanner
bool barbool=false;
// a string to hold incoming data from serial
// a stupid number
int number=0;
void setup(void) {
  // reserve some bytes for the inputString:
  inputString.reserve(50);
  //barcode scanning pins
void loop(void) {
  // picture loop for U8glib lcd libraly
  u8g.firstPage();
  do {
//shows draw2() function on the screen if barcode scanner running
    if(barbool)
      draw2();
    else{
    //shows draw() function on the screen
      draw();
  //run barcode scanner if number set to 5
  if(number==5)
    checkBarcode();
    breakActive = 1;
        bufferPos++;
    // Read the buffer
    int i=0;
        buffer[i] = 0;
        i++;
      barbool=true;
    bufferPos = 0;
    // Blink the LED
    breakActive = 0;
  dataValue = 0;
void draw(void) {
  if(barbool){
void draw2() {
  u8g.drawStr( 0, 20, "ok checked");
int dataRead() {
  byte val = 0;
  return val;
    //if user send 'a' command, set my lovely number 5
      number = 5;
      number = 1;
five is my lovely number. now its auto-formatted.
now what i realised, draw2() never run. when number set 5, program get freeze. while screen frozen, if i scan a valid barcode with barcode scanner (it beep when read) Serial.println() works (prints 5) but draw2() doesn't work.
« Last Edit: February 12, 2013, 07:13:41 am by feveran » Logged
Seattle, WA USA
Seattle, WA USA
The point was that there should be a comment in the code explaining the magic number.
Of course it does.
OP: What happens if you get rid of all the code to draw to the LCD, and just print to the serial port?
Without lcd and u8g libraly, everything goes well. i can read valid barcode number from serial. i think problem can depend on   "picture loop".
Pages: [1] 2   Go Up
