Pages: 1 [2]   Go Down
Author Topic: ps2 barcode scanner using instantly  (Read 414 times)
Seattle, WA USA
Online Online
Seattle, WA USA
Without lcd and u8g libraly, everything goes well.
You then need to include the libraries, and create the instances, but don't use them. Does the code still work?
Add parts back in until the code quits working correctly. Then, let us know what specific line of code/function call causes the program to quit.
Have you checked how much free memory you have?
ok i will work on it.
East Anglia (UK)
May all of your blinks be without delay
Does the capitalisation of the function name matter ?
Of course it does.
In my heart of hearts I knew that, but it would be less confusing if the tutorial on the function http://arduino.cc/en/Tutorial/SerialEvent was consistent as to what it called the function.  Admittedly it is called serialEvent in the example programs but it is referred to as SerialEvent in several places in the text and comments, not least at the very start of the tutorial.
SerialEvent
Demonstrates use of the SerialEvent() function. SerialEvent() is called after a loop(), if there is serial data in the buffer.
Seattle, WA USA
Online Online
Seattle, WA USA
Post this issue in the Website and Forum section. Of late, madbob has been very good at fixing issues in the reference documentation.
East Anglia (UK)
Will do
Pages: 1 [2]   Go Up
