Author Topic: Power line communication  (Read 245 times)
Israel
I have an idea where I need to send a small data packets over the home power lines (similar to those network adapters you plug into the wall instead of using ethernet cables). Does anyone have any experience with such circuits? How small can I make them?
UK
No experience of circuits like that and I'd consider it a very dangerous area to work in, but I've used commercial phone-over-mains and ethernet-over-mains adapters without any problems. Are the standard products out of the question in this case?
Israel
I want to make it small enough to act as an adapter between a light bulb and its socket.
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
Google X 10.
Bob
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
That idea has been thought of before, about 4 maybe 5 years ago. But it was put aside due to noise issues. Maybe it's being worked on again, but I wouldn't expect it any time soon.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
40, maybe 50 years ago.
And I don't know why you would claim it doesn't work because of noise,   there are many successful commercial implementations.
Queens, New York
I was living in Florida at the time, and my friends father worked for the electric company. He was talking about how Comcast and the Keys power service wanted to combine and be able to make all communications through the power lines. After about a year, it was stopped and was complaining about noise issues.
UK
I was involved with an ISP that was using the power lines as a backbone network around that sort of time. They were running it for quite a few years, but I don't know if they're still doing it.
Australia
If you pull apart a commercial power line ethernet adapter, you will see that the limitation on size
is the isolation transformer, thats used to isolate the mains side from the low level logic side.
Not much you can do to make this component physically smaller.
The last thing you did is where you should start looking.
The X-10 TW523 Two-Way Power Line Interface is an option.
http://www.angelfire.com/tv2/fvazquez/docs/Electr/X-10_TW523.pdf
You could write your own protocol.
Now, More Than Ever
carrier current transmitter
Don't Be Upset By The Results You Didn't Get With The Work You Didn't Do
Israel
The isolation transformer is a show stopper :-(
