Pages: [1] 2   Go Down
Author Topic: Clear Screen and 2.8TFT  (Read 319 times)
Hello.
I have been searching around the internet for code to clear my screen inside a simple text sketch on my TFT 2.8 display.
I have searched high and low and only found ways to clear a LCD which is obviously completely different from the TFT... lcd.clear(); did not work even with the library loaded.  ClearScreen(); has not worked at all for me even though I read different ways to type it out so it actually complies but when I run it the text from the screen does not clear.
I guess what I am asking is if there is a "command" within the TFT. library that I can use to clear the screen so I can write again? I was going to just re DigitalWrite all the text in black with no delay to cover it back up to black which would be like a fake clear screen but I said to myself there has to be an easier way.
I start my sketch with
#include <stdint.h>
#include <TouchScreen.h>
#include <TFT.h>
#include <TFT_Graphics.h>
Tft.init();
after a bunch of digitalwrite code I want to clear it to write all over again
thank you
Seattle, WA USA
Seattle, WA USA
Links to the library are going to be necessary.
Im so sorry I should have known better.
http://www.seeedstudio.com/wiki/images/5/53/TFT_Touch_Shield_libraries.zip
thank you for your response smiley
NE PA
Have you tried tft.ClearScreen(WHITE) or tft.ClearScreen(BLACK)?
Manchester (England England)
Solder is electric glue
I use:-
display.clearDisplay();   // clears the screen and buffer
error "'class TFT' has no member named 'ClearScreen'" when I try     Tft.ClearScreen(BLACK)
display.clearDisplay();   // clears the screen and buffer    gives me display is not declared in this scope... so this is probably my error now instead of the library error.... display.clearDisplay(); seems to be doing something but not yet
Have you tried running the examples in the library?
all the examples in the TFT run fine if you mean the "draw circles " "paint" etc they all work just fine.
I am trying to write a text sketch that runs from line 0 to 250 but then I need a wipe to start to write again on line 0.
I am guessing that within TFT library there is a "member" called display or clearDisplay but maybe I am not putting it in the rigth place? is this in void setup or loop because I tried both
I am also very new to this..
should I #include anything other than TFT.h, TFT_graphics.h, etc?
my sketch is very simple to give you an idea. I just want to clear it after it runs so I can go back to line 0 and write more
Tft.init();  //init TFT library
 Tft.drawString("SCAN INITAITED",0,0,2,RED);
 delay(3000);
Tft.drawString("----------7657566470808106647",0,20,1,WHITE);
  delay(2000);
 Tft.drawString("==============476445070416616" ,0,30,1,WHITE);
  delay(2000);
Tft.drawString("Possible Match " ,0,40,2, RED);
 delay (4000);
 Tft.drawString("----------------76466013131",0,60,1,WHITE);
  delay(2000);
 Tft.drawString("------------------267790997",0,70,1,WHITE);
  delay (2000);
 Tft.drawString("----------------------90997",0,80,1,WHITE);
  delay (2000);
 Tft.drawString("-------------------------97",0,90,1,WHITE);
 Tft.drawString("WARNING",10,100,2,RED);
 Tft.drawString("!!!DETECTED!!!",10,120,2,RED);
  delay (3000);
  Tft.drawString("PROX SENSOR",0,140,2,RED);
  Tft.drawString("VER 2.2 !ON!"  ,0,155,2,RED);
So they have the clear the display call in them don't they?
You have to include:-
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
I searched through the code in the sketches of all the TFT examples and none use any clear screen command.
I added the adafruit lines but dont I need one of his libraries like
https://github.com/adafruit/Touch-Screen-Library  ?? first?
Get the Adafruit_SSD1306 library and run the ssd1306_128x64_spi or the  ssd1306_128x64_i2c example sketch, I think that is what you are missing.
So I got the Adafruit_SSD1306 library and installed it, made sure to #include the two ( #include <Adafruit_GFX.h>, #include <Adafruit_SSD1306.h>)
I loaded the  ssd1306_128x64_spi  example up and saw the "display.clearDisplay(); " command in there so i figured since I have the library installed and its included now I should have access to that command?
But I still get..  error: 'display' was not declared in this scope
And whats funny on top of it when I open up the ssd1306_128x64_spi amd try to just verify it I get an error "ssd1306_128x64_spi:335: error: 'class Adafruit_SSD1306' has no member named 'println'" even though its their example.
So after installing it my sketch is as follows.
"#include <stdint.h>
#include <TFT.h>
#ifdef SEEEDUINO
  #define YP A2   // must be an analog pin, use "An" notation!
  #define XM A1   // must be an analog pin, use "An" notation!
  #define YM 14   // can be a digital pin, this is A0
  #define XP 17   // can be a digital pin, this is A3
#endif
#ifdef MEGA
  #define YM 54   // can be a digital pin, this is A0
  #define XP 57   // can be a digital pin, this is A3
#endif
 delay(3000);
  delay(2000);
  delay(2000);
 delay (4000);
  delay(2000);
  delay (2000);
  delay (2000);
 Tft.drawString("WARNING",0,100,2,RED);
 Tft.drawString("!!!10,120,2,RED);
  delay (3000);
am I using the command wrong? or in the wrong spot?
thanks so much mike for all your help
« Last Edit: February 11, 2013, 01:32:11 pm by grindsoul » Logged
Seattle, WA USA
Seattle, WA USA
Your instance of the TFT class is called Tft. Why are you calling clearDisplay() on some non-existent instance?
you mean use "Tft.clearDisplay()" instead of using the "display.clearDisplay()"?
Pages: [1] 2   Go Up
