Loading...
Pages: [1]   Go Down
Author Topic: Function defined in header not available in main file  (Read 93 times)
Offline Offline
Newbie
View Profile
I have a file structure as follows:
Code:
interface.h --> interface.c
effects.h --> effects.c
    main
However, functions declared in effects.h are not accessible in main.
Code snippets :
main :
Code:
#include "interface.h"
#include "effects.h"
void setup()  //Initialize all variables here
turnoff();
effects.h :
Code:
#ifndef EFFECTS
#define EFFECTS
void turnoff();
#endif
effects.c :
Code:
void turnoff()
interface.h :
Code:
#ifndef INTERFACE
#define INTERFACE
#endif
Error message : In function ``loop':undefined reference to ``turnoff()'
Anybody knows whats wrong ?
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
I c what the problem is. Changing to cpp would help.
Logged
Offline Offline
Newbie
View Profile
Why ? Doesnt avr-gcc handle c ??
http://arduino.cc/en/Hacking/BuildProcess
« Last Edit: February 10, 2013, 10:28:52 am by ashrj » Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Yes, it does. However, C++ supports function overloading. That is the same function can be called with different arguments. How do you suppose the compiler knows which code to actually execute when you type Serial.print(val);?
The answer is that every function really gets a different name. That name is made up of the function name and the types of the arguments that the function accepts.
So, Serial.print() for an int is a different name what Serial.print() for a float.
The C++ compiler is looking for a function based on the name and the arguments that the function accepts.
The C compiler, because it does not support function overloading, knows that the function name is unique, so it doesn't mangle the name.
The linker, then, can't find the mangled name it is looking for in the object file produced by the C compiler.
Logged
Offline Offline
Newbie
View Profile
I changed the files to .cpp and it worked. What I still dont understand is why ? If my project is completely in C or C++ then the linker should be able to handle it. What you describe should cause problems when i mix C and C++ together, if I understood you correctly.
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
I described why. You could google "C++ name mangling" for more details.
Quote
And it can. The IDE creates a cpp file from the sketch, though.
Quote
Well? Didn't it?
Logged
Pages: [1]   Go Up
Print
Jump to:
