Topic: Detecting when a LiPo battery connected trough a step-up board has low power. (Read 755 times) previous topic - next topic
amundsen
Hello,
I have a 5V Pro Mini Arduino I intend to connect to a 3.7V Lipo battery trough a step-up board (http://dx.com/p/lm2577-dc-3-5-18v-to-dc-4-0-24v-voltage-step-up-boost-module-red-154906)
I would like a LED to be lit when the battery is getting empty. Can I connect the battery to an analog input of the Arduino trough a resistor and detect when the value decreases under a specific voltage threshold ? Or is there a better way to do it ?
Thank you in advance.
retrolefty
Hello,
That should work, and there is no real reason to use a resistor as a analog input pin is high impedance and will not draw any significant current from the battery. A reading of 3.0vdc is a generally used common value to stop drawing current from the lipo cell to prevent cell damage.
Lefty
amundsen
MarkT
I'd include the resistor, something like 1k to 10k is fine, just to prevent the risk of accidental short(*) on the traces of the Arduino
grounding the LiPo - massive currents would then flow, vaporising pcb traces.  LiPo's can put out 50 to 100A or more if abused...
(*) Accidentally put the board down on top of something metal for instance.
