Topic: LØST Capacitive Sens (Read 5216 times) previous topic - next topic
lydfanger
Feb 10, 2013, 09:26 pm Last Edit: Feb 21, 2013, 12:05 am by lydfanger Reason: 1
Hej igen XD
Jeg er begyndt at udforske import af biblioteker og fandt et spændende projekt med CapacitiveSens. Sketch'en er færdig skrevet, hentet fra Arduino's hjemmeside, Bilblioteks filen en lagt i biblioteket og kan ses i IDE'en.
Derfor undre det mig at jeg får fejlmeldinger som:
CapacitiveSensor'does not name a type
og
'cs_4_2' was not declared in this scope
Er der nogen som kan gennemskue hvad der er "galt", eller hvad jeg overser", i forhold til nedenstående sketch.
#include <CapacitiveSensor.h>
* CapitiveSense Library Demo Sketch
* Paul Badger 2008
* Uses a high value resistor e.g. 10 megohm between send pin and receive pin
* Resistor effects sensitivity, experiment with values, 50 kilohm - 50 megohm. Larger resistor values yield larger sensor values.
* Receive pin is the sensor pin - try different amounts of foil/metal on this pin
* Best results are obtained if sensor foil and wire is covered with an insulator such as paper or plastic sheet
CapacitiveSensor   cs_4_2 = CapacitiveSensor(4,2);        // 10 megohm resistor between pins 4 & 2, pin 2 is sensor pin, add wire, foil
CapacitiveSensor   cs_4_5 = CapacitiveSensor(4,5);        // 10 megohm resistor between pins 4 & 6, pin 6 is sensor pin, add wire, foil
CapacitiveSensor   cs_4_8 = CapacitiveSensor(4,8);        // 10 megohm resistor between pins 4 & 8, pin 8 is sensor pin, add wire, foil
  cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF);     // turn off autocalibrate on channel 1 - just as an example
   long start = millis();
   long total1 =  cs_4_2.capacitiveSensor(30);
   long total2 =  cs_4_5.capacitiveSensor(30);
   long total3 =  cs_4_8.capacitiveSensor(30);
   Serial.print(millis() - start);        // check on performance in milliseconds
   Serial.print("\t");                    // tab character for debug windown spacing
   Serial.print(total1);                  // print sensor output 1
   Serial.print("\t");
   Serial.print(total2);                  // print sensor output 2
   Serial.print("\t");
   Serial.println(total3);                // print sensor output 3
   delay(10);                             // arbitrary delay to limit data to serial port
Vh
LYDFANGER
3dprinter
Uden at have kigget på det library, så "plejer" det at være at hvis librariet har defineret en class så initaliserer man :
CapacitiveSensor   cs_4_2 (4,2);
å skulel du have dit cs_4_2 object som du bruger so du allerede gør.
lydfanger
Nu har jeg forenklet lidt i sketch'en, og tilføjet det du nævnte.
Nu får jeg følgende melding
"CapacitiveSensor' does not name a type".
    long total1 =  cs_4_2.CapacitiveSensor(30);
Erni
Det er da virkelig også noget rod.
1. Biblioteket skal hedde Capsense, ligesom de filer der er i biblioteket CapSense.h og CapSense.cpp
2. I de to filer skal du udskifte
#include "WProgram.h"
med
#include "Arduino.h"
3. Navneforvirringen i punkt 1, gør at navnene skal ændres i sketchen, se nedenfor.
Nu kan sketchen compiles, men om den virker efter hensigten ved jeg ikke
#include <CapSense.h>
* Paul Badger 2008
CapSense   cs_4_2 = CapSense(4,2);        // 10 megohm resistor between pins 4 & 2, pin 2 is sensor pin, add wire, foil
CapSense   cs_4_5 = CapSense(4,5);        // 10 megohm resistor between pins 4 & 6, pin 6 is sensor pin, add wire, foil
CapSense   cs_4_8 = CapSense(4,8);        // 10 megohm resistor between pins 4 & 8, pin 8 is sensor pin, add wire, foil
    long total1 =  cs_4_2.capSense(30);
    long total2 =  cs_4_5.capSense(30);
    long total3 =  cs_4_8.capSense(30);
    Serial.print("\t");
    Serial.print("\t");
lydfanger
Tak for svarene
Efter jeg prøvede det I skrev i jeres indlæg meldte IDE stadig fejl.
Jeg tog internettet til hjælp og fandt ud af, der i den ene libraries fil var en henvisning til et libraries "Wconstance.h". Filen er ikke nødvendig og er derfor fjernet.
Så nu virker tingene sammen.
Skal det forståes sådan at en libraries fil, kan include en helt tredje fil?
Vh
Lydfanger
3dprinter
Yep. En fil der bruges med din #include kan i sig selv bruge en anden fil med #include, og så videre op til et vist antal, nok 1023 dyb (who cares? det vil være nok til almindelig brug) Det behøver ikke være en Library, filens indhold bliver sat ind i stedet for #include, og kan derfor vare hvilken som helst tekst.
