Hi all,
I have the below code that is taken and adapted from other members of this forum and the www. Everything works great with it except the analogWrite() function towards the bottom of the file. The way it works is that I hit an IP (ie. http:10.0.0.1/analogWrite/5/200) and it parses it and sets the pwm pin 5 to a setting of 200. I guess the only problem is that the analogWrite doesn't work, the digitalWrite works beautifully though. What actually happens when I visit the analogWrite link mentioned above is that the led, which is in a low pass filter, flashes briefly and doesn't stay on. I know it isn't a filter problem because I wrote a really simple sketch that just sets the analogWrite values outright and it behaves fine. Any ideas? I know its a little messy and the stuff towards the top is just so I can see the pin states while I am working with it. Thanks for any suggestions.
//ARDUINO 1.0+ ONLY
//ARDUINO 1.0+ ONLY
#include <Ethernet.h>
#include <SPI.h>
boolean reading = false;
//CONFIGURE
byte ip[] = { 192, 168, 0, 30 }; //Manual setup only
byte gateway[] = { 192, 168, 0, 1 }; //Manual setup only
byte subnet[] = { 255, 255, 255, 0 }; //Manual setup only
// if need to change the MAC address (Very Rare)
EthernetServer server = EthernetServer(80); //port 80
int ledPin = 13;
#define bufferMax 128
int bufferSize;
char buffer[bufferMax];
char cmd[15]; // Nothing magical about 15, increase these if you need longer commands/parameters
char param1[15];
char param2[15];
void setup(){
//Pins 10,11,12 & 13 are used by the ethernet shield
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
//Ethernet.begin(mac);
Ethernet.begin(mac, ip, gateway, subnet); //for manual setup
server.begin();
Serial.println(Ethernet.localIP());
void loop(){
// listen for incoming clients, and process qequest.
// checkForClient();
if (client) {
WaitForRequest(client);
ParseReceivedRequest();
PerformRequestedCommands();
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if(reading && c == ' ') reading = false;
if(c == '?') reading = true; //found the ?, begin reading the info
char d = 'a';
if(reading){
Serial.print(c);
char d = c;
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Connnection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// add a meta refresh tag, so the browser pulls again every 10 seconds:
client.println("<meta http-equiv=\"refresh\" content=\"10\">");
// output the value of each analog input pin
//client.print("this is a test");
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("<br />");
for (int digitalChannel = 0; digitalChannel < 10; digitalChannel++) {
int sensorReading = digitalRead(digitalChannel);
client.print("Digital PinMode ");
client.print(digitalChannel);
client.println("c=");
client.println(c);
client.println("p1=");
client.println(param1);
client.println("p2=");
client.println(param2);
client.println("</html>");
break;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
void WaitForRequest(EthernetClient client) // Sets buffer[] and bufferSize
bufferSize = 0;
if (c == '\n')
break;
if (bufferSize < bufferMax)
buffer[bufferSize++] = c;
break;
PrintNumber("bufferSize", bufferSize);
void ParseReceivedRequest()
Serial.println("in ParseReceivedRequest");
Serial.println(buffer);
//Received buffer contains "GET /cmd/param1/param2 HTTP/1.1". Break it up.
char* slash1;
char* slash2;
char* slash3;
char* space2;
slash1 = strstr(buffer, "/") + 1; // Look for first slash
slash2 = strstr(slash1, "/") + 1; // second slash
slash3 = strstr(slash2, "/") + 1; // third slash
space2 = strstr(slash2, " ") + 1; // space after second slash (in case there is no third slash)
if (slash3 > space2) slash3=slash2;
PrintString("slash1",slash1);
PrintString("slash2",slash2);
PrintString("slash3",slash3);
PrintString("space2",space2);
// strncpy does not automatically add terminating zero, but strncat does! So start with blank string and concatenate.
cmd[0] = 0;
param1[0] = 0;
param2[0] = 0;
strncat(cmd, slash1, slash2-slash1-1);
strncat(param1, slash2, slash3-slash2-1);
strncat(param2, slash3, space2-slash3-1);
PrintString("cmd",cmd);
PrintString("param1",param1);
PrintString("param2",param2);
void PerformRequestedCommands()
if ( strcmp(cmd,"digitalWrite") == 0 ) RemoteDigitalWrite();
if ( strcmp(cmd,"analogWrite") == 0 ) RemoteAnalogWrite();
void RemoteDigitalWrite()
int ledPin = param1[0] - '0'; // Param1 should be one digit port
int ledState = param2[0] - '0'; // Param2 should be either 1 or 0
digitalWrite(ledPin, ledState);
void RemoteAnalogWrite()
// If desired, use more server.print() to send http header instead of just sending the analog value.
int pwmPin = param1[0] - '0'; // Param1 should be one digit analog port
int pwmState = param2[0] - '0'; // Param2 should be between 0 and 255
analogWrite(pwmPin, pwmState);
void PrintString(char* label, char* str)
Serial.print(label);
Serial.print("=");
Serial.println(str);
void PrintNumber(char* label, int number)
Serial.print("=");
Serial.println(number, DEC);
