« on: February 10, 2013, 07:17:47 pm » |
I am working on a sculpture that includes three servos, 4 x 12v motors, and 30 LED's. The three servos are running well on a 6v/1.5 amp wall wart. The additional three motors (12v, 500 mA each) will be ready for testing in a few day. Ideally, I would like to use a single power supply for the entire project. Something ready made wold be great but I see no Wall Wart rated more than 2 Amp. Is there something salvageable? If not, do I have to order a transformer, rectify it from scratch? If the total is 5 amps, do I make a rail and regulate with 78-- or LM317?
« Reply #1 on: February 10, 2013, 07:56:34 pm » |
A 78-- or LM317 are for 1A or a little more and they get hot, you might need a heatsink. A DC-DC converter is very efficient.
Do you use an Arduino and a motor driver ? If the servos are 6V, you could use a DC-DC converter to 6V and use it for the adapter plug (or Vin) of the Arduino and the servos.
If you can power the leds with 12V or a with second DC-DC converter, you would only need a power supply of 12V.
« Reply #2 on: February 10, 2013, 09:30:09 pm » |
Are the DC to DC converters you describe the same as "buck converters? I am looking at tutorials to understand your suggestion. Are these circuits or a single component?
Boston area, metrowest
« Reply #3 on: February 11, 2013, 12:07:19 am » |
Check mpja.com - lots of supplies available, many with multiple outputs http://www.mpja.com/12-Volt-Power-Supply/products/537/
« Reply #4 on: February 11, 2013, 03:28:03 am » |
DC-DC converters is a common name for step-up, step-down, boost and buck-boost converters. Sometimes it is a small black box (with the components inside), but mostly it is a circuit board. Some examples: http://www.ebay.com/sch/i.html?_nkw=dc+dc+converter
« Last Edit: February 11, 2013, 03:29:55 am by Krodal »
« Reply #5 on: February 11, 2013, 08:05:01 am » |
« Reply #6 on: February 11, 2013, 09:09:24 am » |
The second one (DC-DC Buck converter) is okay. If 2A is okay for you.
I have doubts about the first one (switching power supply 12Volt 5 Amp). I bought a few switching power supplies from Ebay, and most of them can not deliver the current and they get overheated and get broken within a few month.
If you would also use a DC-DC converters for the motors, you don't need a regulated power supply. Perhaps you have some DC power supply already ? Or an adaptor of 19V for a laptop.
« Reply #7 on: February 11, 2013, 09:18:57 am » |
So if the total amps is around 5, what should I use for a power supply? Hopefully, something I could find at Goodwill?
« Reply #8 on: February 11, 2013, 04:22:43 pm » |
Did you look at mpja.com at all? They have high current suppllies available. You could use a 12V, 4A supply and use smaller switching adapters for the lower voltages http://www.pololu.com/catalog/category/84
« Reply #9 on: February 11, 2013, 09:12:56 pm » |
« Reply #10 on: February 11, 2013, 09:25:31 pm » |
« Reply #12 on: February 12, 2013, 08:36:26 am » |
Sorry, a dumb question: What happens to the unused amps? Any problem running these motors directly from the power supply? Can both current and voltage be adjusted? I have ordered DC to DC converters. Thank you so much for the advice. The typical small, Arduino board driven projects I have worked with before have not been so challenging in terms of power supply.
