Loading...
Pages: [1]   Go Down
Author Topic: controlling loops with separate pushbuttons  (Read 224 times)
Offline Offline
Newbie
View Profile
Hello, I was wondering if I could get some help with my project. I made nerf bars for my truck and I'm trying to set up a system with 3 momentary switches to control light patterns. there are 5 lights on each side of the truck and I want to do a back and forth scanner, a scanner that goes from both ends and meets in the middle, and a setting where they stay on steady. I have the circuitry built with transistors and everything and I have chunks of code set up to sequence the lights, but I can't figure out how to structure the whole thing. I was messing around with if then statements, but I think the program will just get stuck on whichever button is pressed first until the power is reset. I know each pattern will need a loop to keep repeating, but how do I interrupt the loop with one of the other switches and switch to a different loop?
Logged
California
Online Online
Edison Member
View Profile
You need to re-structure your code so that you aren't performing any blocking type functions like delay(). There is an example called Blink Without Delay that you should study. Also, when asking for help in this section, it's a good idea to read the thread entitled "Read this before posting a programming question...", specifically the section 6.
Logged
Offline Offline
Full Member
W9LZ
View Profile
Congratulations on your very first post!  Send a copy of what you have put together so far.
Logged
Offline Offline
Newbie
View Profile
Okay so I changed my setup to use a 3 position rotary switch and I am trying to use while loops to run different functions but when I hook it all up nothing happens. The functions all work when separately uploaded. Can you set up multiple while loops like this? Only one input will be HIGH at a time. ( I know there's simpler ways to sequence the leds but I can't follow the code yet, this is simpler for me)
Code:
const int ledPin2 = 2;
const int ledPin3 = 3;
const int ledPin4 = 4;
const int ledPin5 = 5;
const int ledPin6 = 6;
const int wait = 45;
const int wait1 = 45;
const int wait2 = 1000;
const int inputSequence = 10;            //yellow wire
const int inputDual = 11;                //blue wire
const int inputOn = 12;                  //green wire
void setup(){
  pinMode(ledPin2, OUTPUT);
  pinMode(ledPin3, OUTPUT);
  pinMode(ledPin4, OUTPUT);
  pinMode(ledPin5, OUTPUT);
  pinMode(ledPin6, OUTPUT);
  pinMode(inputSequence, INPUT);
  pinMode(inputDual, INPUT);
  pinMode(inputOn, INPUT);
void loop(){
  while (inputSequence == HIGH){
    Sequence();
  while (inputDual == HIGH){
    Dual();
  while (inputOn == HIGH){
    On();
void Sequence(){
      digitalWrite(ledPin2, HIGH);
      delay(wait1);
      digitalWrite(ledPin2, LOW);
      delay(wait);
      digitalWrite(ledPin3, HIGH);
      delay(wait1);
      digitalWrite(ledPin3, LOW);
      delay(wait);
      digitalWrite(ledPin4, HIGH);
      delay(wait1);
      digitalWrite(ledPin4, LOW);
      delay(wait);
      digitalWrite(ledPin5, HIGH);
      delay(wait1);
      digitalWrite(ledPin5, LOW);
      delay(wait);
      digitalWrite(ledPin6, HIGH);
      delay(wait1);
      digitalWrite(ledPin6, LOW);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait2);
void Dual(){
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait2);
void On(){
Logged
'round the world...
Offline Offline
Edison Member
View Profile
WWW
What should happen if you push two buttons at the same time?
Is there a priority to the sequences that you want to implement, or do you just want to run if there is a single selection made?
If that is the case...
Code:
while ((inputSequence == HIGH) && (inputDial == LOW) && (inputOn == LOW)){
    Sequence();
This guarantees that for any lights to turn on you need to only have one selection made. But if this is a selection switch... this isn't useful.
How did you hook up your selection switch? Any Pull-up resistors there?
Try this:
Code:
  digitalWrite(inputSequence, HIGH);       // turn on pullup resistors
  digitalWrite(inputDual, HIGH);       // turn on pullup resistors
  digitalWrite(inputOn, HIGH);       // turn on pullup resistors
Apart from the pull-up resistors can't think of anything that would cause this not to work.
You must understand that once you change the selection, the function has to end running before the new sequence can start. That can take a couple of seconds.
Logged
Eu não sou o teu criado. Se respondo no fórum é para ajudar todos mediante a minha disponibilidade e disposição. Responder por mensagem pessoal iria contra o propósito do fórum e por isso evito-o.
Se realmente pretendes que eu te ajude por mensagem pessoal, então podemos chegar a um acordo e contrato onde me pagas pela ajuda que eu fornecer e poderás então definir os termos de confidencialidade do meu serviço. De forma contrária toda e qualquer ajuda que eu der tem de ser visível a todos os participantes do fórum (será boa ideia, veres o significado da palavra fórum).
Nota também que eu não me responsabilizo por parvoíces escritas neste espaço pelo que se vais seguir algo dito por mim, entende que o farás por tua conta e risco.
Dito isto, mensagens pessoais só se forem pessoais, ou seja, se já interagimos de alguma forma no passado ou se me pretendes convidar para uma churrascada com cerveja (paga por ti, obviamente).
Offline Offline
Newbie
View Profile
Haha I enabled those right before I read your post bubulindo, I rewired the switch to give a ground to any one of the inputs but it's stuck on Sequence still
edit* I also changed the triggers on the while loops from HIGH to LOW. It seems like I need to have a way to have each loop check the switch and jump back to the main loop
« Last Edit: February 12, 2013, 11:20:10 pm by technic6490 » Logged
Offline Offline
Full Member
W9LZ
View Profile
How about incorporating a "switch" statement and wrapping your sequencer functions?
switch (position of switch or 2 pushbuttons to give you '00' '01' '10' '11' values )
       case '1':
       Sequence1();
       case '2':
       Sequence2();
       case '3'
       Sequence3();
Logged
California
Online Online
Edison Member
View Profile
Code:
void loop(){
    Sequence();
    Dual();
    On();
Why are you comparing the pin numbers of your switch to a state?
This is a perfect example of why you should be using more descriptive names like inputSequencePin, inputDualPin, inputOnPin.
Logged
Offline Offline
Newbie
View Profile
I renamed my pin designations and tried a switch statement but now all it does is skip to the last sequence. It looks like it should work to me
Code:
const int inputSequencePin = 10;                //yellow wire 10
const int inputDualPin = 11;                    //blue wire 11
const int inputOnPin = 12;                      //green wire 12
int var = 0;
void setup(){
  pinMode(inputSequencePin, INPUT);
  digitalWrite(inputSequencePin, HIGH);          //enable pull-up resistor
  pinMode(inputDualPin, INPUT);
  digitalWrite(inputDualPin, HIGH);              //enable pull-up resistor
  pinMode(inputOnPin, INPUT);
  digitalWrite(inputOnPin, HIGH);                //enable pull-up resistor
void loop(){
  if (digitalRead(inputSequencePin == LOW))      //yellow wire 10
    var = 1;
  if (digitalRead(inputDualPin == LOW))          //blue wire 11
    var = 2;
  if (digitalRead(inputOnPin == LOW))            //green wire 12
    var = 3;
  switch (var){
    case 1:
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait2);
    case 2:
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait);
      delay(wait1);
      delay(wait2);
    case 3:
Logged
Milton Keynes UK
Offline Offline
Tesla Member
View Profile
Code:
var = 1;
var = 2;
var = 3;
Should be:
Code:
if (digitalRead(inputSequencePin) == LOW)      //yellow wire 10
var = 1;
if (digitalRead(inputDualPin) == LOW)          //blue wire 11
var = 2;
if (digitalRead(inputOnPin) == LOW)            //green wire 12
var = 3;
Logged
Offline Offline
Newbie
View Profile
That did it! Thank you everyone!
Logged
Pages: [1]   Go Up
Print
Jump to:
