Topic: moisture sensors (Read 2892 times) previous topic - next topic
s1lim
PaulS
Quote
example please
Code: [Select]
   int val0 = analogRead(A0);
   int val1 = analogRead(A1);
   int val2 = analogRead(A1);
   int val3 = analogRead(A3);
   if(val0 < MOISTURE_LEVEL)
      digitalWrite(valvePin0, HIGH);
       digitalWrite(valvePin0, LOW);
   // replicate for the other 3 valve pins
   if(val0 < MOISTURE_LEVEL ||
       val1< MOISTURE_LEVEL ||
       val2< MOISTURE_LEVEL ||
       val3< MOISTURE_LEVEL)
      digitalWrite(pumpPin, HIGH);
      digitalWrite(pumpPin, LOW);
What this is doing is opening the correct valve if a sensor is dry, and then, if any sensor is dry, turning the pump on.
Notice that the action of opening a valve is separated from the action of turning the pump on, because the pump condition is dependent on any sensor, while the valves are dependent on a specific sensor.
s1lim
thanku ill give this a try....
s1lim
It works perfect thank u so much.....if i were to add buttons would i do them the same ?
s1lim
again thank you....this is what i've come up with so for all of it works....
Code: [Select]
const int TxPin = 6;       //lcd pin
const int relayPin1 = 4;  //pins that are for
const int relayPin2 = 3;  //buttons to open valves
const int relayPin3 = 2;                       // and pumps
const int relayPin4 = 5;
const int relayPin5 = 7;
const int pumpPin = 9;        //pin that turns on the pump
const int valvePin1 = 13;        //pins that run valves
const int valvePin2 = 12;
const int valvePin3 = 11;
const int valvePin4 = 10;
const int PROBE1=A0, PROBE2=A1, PROBE3=A2, PROBE4=A3;
int MOISTURE_LEVEL = 250;                              //the value after the valves and pump goes ON
#include <SoftwareSerial.h>
SoftwareSerial mySerial = SoftwareSerial(255, TxPin);
   pinMode(relayPin5, OUTPUT);
   pinMode(relayPin4, OUTPUT);
   pinMode(relayPin1, OUTPUT);
   pinMode(relayPin2, OUTPUT);
   pinMode(relayPin3, OUTPUT);
   pinMode(pumpPin,OUTPUT);    // sets pumpPin to output
   pinMode(valvePin1,OUTPUT);    // sets valvePins to output
   pinMode(valvePin2,OUTPUT);
   pinMode(valvePin3,OUTPUT);
   pinMode(valvePin4,OUTPUT);
   pinMode(TxPin, OUTPUT);          //lcd pin to output
   digitalWrite(TxPin, HIGH);
   digitalWrite  (valvePin1,LOW);
   digitalWrite(valvePin2,LOW);
   digitalWrite(valvePin3,LOW);
   digitalWrite(valvePin4,LOW);
   digitalWrite(relayPin1,LOW);
   digitalWrite(relayPin2,LOW);
   digitalWrite(relayPin3,LOW);
   digitalWrite(relayPin4,LOW);
   digitalWrite(relayPin5,LOW);
   mySerial.begin(9600);
   mySerial.write(22);                // turns display on
   mySerial.write(17);                // turn on lcd back light
   mySerial.write(12);                 // Clear  LCD
   delay(5);                          //required delay after clear Lcd
   int val2 = analogRead(A2);
   mySerial.write(128);
  mySerial.print("S1-");
   mySerial.write(148);
  mySerial.print( "S2-");
  mySerial.write(168);
  mySerial.print("S3-");
   mySerial.write(188);
  mySerial.print( "S4-");
   mySerial.write(132);
  mySerial.print (analogRead(A0));
   mySerial.write(152);
  mySerial.print (analogRead(A1));
   mySerial.write(172);
  mySerial.print (analogRead(A2));
    mySerial.write(192);
  mySerial.print (analogRead(A3));
      digitalWrite(valvePin1, HIGH);
      digitalWrite(relayPin1, HIGH);
       digitalWrite(valvePin1, LOW);
       digitalWrite(relayPin1, LOW);
   if(val1 < MOISTURE_LEVEL)
      digitalWrite(valvePin2, HIGH);
      digitalWrite(relayPin2, HIGH);
       digitalWrite(valvePin2, LOW);
       digitalWrite(relayPin2, LOW);
   if(val2 < MOISTURE_LEVEL)
      digitalWrite(valvePin3, HIGH);
      digitalWrite(relayPin3, HIGH);
       digitalWrite(valvePin3, LOW);
       digitalWrite(relayPin3, LOW);
   if(val3 < MOISTURE_LEVEL)
      digitalWrite(valvePin4, HIGH);
      digitalWrite(relayPin4, HIGH);
       digitalWrite(valvePin4, LOW);
        digitalWrite(relayPin4, LOW);
      digitalWrite(relayPin5, HIGH);
      digitalWrite(relayPin5, LOW);
i would love to add buttons to control each valve..
PaulS
You should create an lcdInit() function, and another function to write that data to the LCD. Why are you reading from the analog pins again? You should be printing the values in val0, val1, val2, and val3.
You have not defined any switch pins, set them to INPUT, enabled any pullup resistors, or read any switch states.
What do the relay pins control? What do the valve pins control? Will the switch pins override the moisture sensors?
When do you plan to learn about arrays? Functions?
s1lim
the valvepin  are  leds to show which valves are open and the pump is on...the relaypins control one pump and four valves. i ve been reading about arrays but really dont understand them or how i would use them....
