Author Topic: Unable to locate library files  (Read 489 times)
I'm trying to convert from PICs to Arduino and learn by example by downloading code for specific projects and adapting them for use.  EG, my first project is to be an Aquarium controller, but rather than re-invent the wheel, have located a source code in the public domain.  OK some of the components I probably won't use for my controller, but the thing that I find frustrating is that often or not the include files are not linked or contained in the zip files.  I've been googling for the following, and would welcome any pointers as to their location
#include <Arduino.h>
#include <FormatDouble.h>
Trying to compile the code I get a an "fmtDouble was not declaired in this scope" error
Portugal
Tomorrow I will know a BIT more than yesterday
If the library is not native you should include it with " " like this:
#include "FormatDouble.h"
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
Melbourne, Australia
Shannon Member
Lua rocks!
The #include should be in the main sketch file (the .ino file) in addition to any other files where it might be required.
You have to install the library(s) in the right spot and then restart the IDE.
http://arduino.cc/en/Guide/Libraries
Hi guys, thanks for the input.
I'm aware of how to copy the library files to the library folder and restarting the IDE, what I'm struggling with is locating these library files on the net so I can install them...  I'll try Hugo's suggestion to see if it compiles and runs
Shannon Member
Lua rocks!
It's unusual for a library to not be self-contained. Can you give a link to a problem one? And show the code you are using to use that library?
You shouldn't need the quotes rather than brackets when including a library file. Does the file actually exist inside the library?
I don't see how changing #include "foo.h" to #include <foo.h> is going to help if you don't actually have foo.h. That's the point that isn't clear.
Hi Nick,
Here's the link to the guys site http://arduino-aquarium.blogspot.co.uk/p/software.html
and here is the hub link https://github.com/RogerReed/Arduino-Aquarium
Hope that helps.
UK
If you're struggling to locate a particular library used in a specific project then it may be more productive to contact the author of that project for support.
Hopefully they can tell you where to get the library. It may be one of their own for that particular sketch.
Shannon Member
Lua rocks!
Arduino.h is part of the Arduino IDE.
Shannon Member
Lua rocks!
As for FormatDouble, I can't find that either. You could write to the author.
However judging by this:
  fmtDouble(overflowTempSmoothed, 2, tempBuffer, 7);
All it does is take a double, and format it into a temporary buffer. You should be able to write your own replacement. sprintf on this platform doesn't support float/double but I'm sure there is a way, I just can't recall what it is right now.
This thread might help:
http://arduino.cc/forum/index.php/topic,44216
That particular author did not include the libraries (he probably assumed they were widely available).
Thanks for the further replies guys.  I had posted the question on the authors blog site, so hopefully I may get a reply as further searching hasn't thrown up anything yet.
@Nick - I don't know about writing a substitute... I'm very much a newbie to this in terms of how the AVR works and the C style language...
Shannon Member
Lua rocks!
Well, the function from the page I linked even has the same name, so you might guess that is the one you want. Remove the #include for FormatDouble, and just paste the code into your sketch (eg. near the bottom):
void fmtDouble(double val, byte precision, char *buf, unsigned bufLen = 0xffff);
unsigned fmtUnsigned(unsigned long val, char *buf, unsigned bufLen = 0xffff, byte width = 0);
// Produce a formatted string in a buffer corresponding to the value provided.
// If the 'width' parameter is non-zero, the value will be padded with leading
// zeroes to achieve the specified width.  The number of characters added to
// the buffer (not including the null termination) is returned.
unsigned
fmtUnsigned(unsigned long val, char *buf, unsigned bufLen, byte width)
  if (!buf || !bufLen)
    return(0);
  // produce the digit string (backwards in the digit buffer)
  char dbuf[10];
  unsigned idx = 0;
  while (idx < sizeof(dbuf))
    dbuf[idx++] = (val % 10) + '0';
    if ((val /= 10) == 0)
      break;
  // copy the optional leading zeroes and digits to the target buffer
  unsigned len = 0;
  byte padding = (width > idx) ? width - idx : 0;
  char c = '0';
  while ((--bufLen > 0) && (idx || padding))
    if (padding)
      padding--;
      c = dbuf[--idx];
    *buf++ = c;
    len++;
  // add the null termination
  *buf = '\0';
  return(len);
// Format a floating point value with number of decimal places.
// The 'precision' parameter is a number from 0 to 6 indicating the desired decimal places.
// The 'buf' parameter points to a buffer to receive the formatted string.  This must be
// sufficiently large to contain the resulting string.  The buffer's length may be
// optionally specified.  If it is given, the maximum length of the generated string
// will be one less than the specified value.
// example: fmtDouble(3.1415, 2, buf); // produces 3.14 (two decimal places)
void
fmtDouble(double val, byte precision, char *buf, unsigned bufLen)
    return;
  // limit the precision to the maximum allowed value
  const byte maxPrecision = 6;
  if (precision > maxPrecision)
    precision = maxPrecision;
  if (--bufLen > 0)
    // check for a negative value
    if (val < 0.0)
      val = -val;
      *buf = '-';
      bufLen--;
    // compute the rounding factor and fractional multiplier
    double roundingFactor = 0.5;
    unsigned long mult = 1;
    for (byte i = 0; i < precision; i++)
      roundingFactor /= 10.0;
      mult *= 10;
    if (bufLen > 0)
      // apply the rounding factor
      val += roundingFactor;
      // add the integral portion to the buffer
      unsigned len = fmtUnsigned((unsigned long)val, buf, bufLen);
      buf += len;
      bufLen -= len;
    // handle the fractional portion
    if ((precision > 0) && (bufLen > 0))
      *buf++ = '.';
      if (--bufLen > 0)
        buf += fmtUnsigned((unsigned long)((val - (unsigned long)val) * mult), buf, bufLen, precision);
  // null-terminate the string
  *buf = '\0';
Example of doing exactly that, with a test inside setup:
unsigned
    return(0);
  char dbuf[10];
  unsigned idx = 0;
      break;
  unsigned len = 0;
  char c = '0';
    if (padding)
      padding--;
      c = dbuf[--idx];
    *buf++ = c;
    len++;
  *buf = '\0';
  return(len);
void
    return;
  if (--bufLen > 0)
    if (val < 0.0)
      val = -val;
      *buf = '-';
      bufLen--;
      mult *= 10;
    if (bufLen > 0)
      buf += len;
      bufLen -= len;
      *buf++ = '.';
      if (--bufLen > 0)
  *buf = '\0';
void setup ()
  Serial.begin (115200);
  // test
  char buf [20];
  fmtDouble(3.1415, 5, buf);
  Serial.println (buf);
  }  // end of setup
void loop ()
  }  // end of loop
Shannon Member
Lua rocks!
I turned that function into a library, so you can just go ahead with the original code now.
Download from:
http://gammon.com.au/Arduino/FormatDouble.zip
Install in the usual way.
Test:
void setup ()
  char buf [20];
  fmtDouble(3.1415, 5, buf, sizeof buf);
  }  // end of setup
void loop () { }
I'm not promising it works perfectly, I didn't look at the function that closely. But my test works. smiley
« Last Edit: February 11, 2013, 05:29:08 pm by Nick Gammon » Logged
Thanks Nick.
I've been away from the board for a few days. In desperation to get the project off the ground I've dusted off my EasyPIC5 board and went back to programming in PicBASICpro  smiley-red  I may revert back and give the Arduino another run, but feel (for me with my limited level of programming skills) that hunting for library files, the structure and syntax of the programming language frustrating.
