Loading...
Pages: [1]   Go Down
Author Topic: 5x7 dot matrix  (Read 137 times)
Beijing
Offline Offline
Full Member
Skype name habib.derbyshire
View Profile
WWW
Hi all! I was trying to get a 5x7 dot matrix to work. I started with this:
Code:
int columns[]={13, 12, 11, 10, 9};
int rows[]={8, 7, 6, 5, 4, 3, 2};
void setup(){
  for(int i=0; i<=4; i++){
    pinMode(columns[i], OUTPUT);
  for(int i=0; i<=6; i++){
    pinMode(rows[i], OUTPUT);
void loop(){
  dot(2, 1);
void dot(int col, int row){
  for(int i=0; i<4; i++){
    digitalWrite(rows[i], LOW);
  for(int i=0; i<6; i++){
    digitalWrite(columns[i], HIGH);
  digitalWrite(rows[row], LOW);
  digitalWrite(columns[col], HIGH);
and what I get is a whole row lighting up. Why is this?
Logged
What is man's best friend? The breadboard!
East Anglia (UK)
Online Online
Edison Member
May all of your blinks be without delay
View Profile
Code:
It looks to me as though your rows and columns are mixed up in this function.  Also
Code:
loops 6 times and
Code:
loops 4 times but you say that your matrix is 5x7
How are the LEDs wired ?
Logged
Milton Keynes UK
Offline Offline
Tesla Member
View Profile
Delete all the hardcoded literal values for the number of rows and columns, and replace them with defined constants. For example:
Code:
const byte COLUMN_COUNT = 5;
const byte ROW_COUNT = 7;
When looping through rows and columns always use these values, like this:
Code:
for(int r = 0; r < ROW_COUNT; r++)
  digitalWrite(rows[r], LOW);
for(int c = 0; c < COLUMN_COUNT; c++)
  digitalWrite(columns[c], HIGH);
Logged
Beijing
Offline Offline
Full Member
View Profile
WWW
Thanks a lot. I modified the code, here it is.
Code:
const byte COLUMN_COUNT=5;
const byte ROW_COUNT=7;
void setup(){
void loop(){
  dot(2, 1);
    digitalWrite(rows[i], HIGH);
    digitalWrite(columns[i], LOW);
My dot matrix is a generic 12 pin 5x7, I don't have a schematic. After modifing the code, the first, second, sixth and seventh rows of the first column light up.
Logged
Milton Keynes UK
Offline Offline
Tesla Member
View Profile
You have added the constant definitions but you have completely ignored all the other suggestions I made.
Logged
Beijing
Offline Offline
Full Member
View Profile
WWW
Oops... Sorry.
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
Why use ints to count from 0 to less than 10?
Was that a conscious choice or just following a grooved-in habit to save actual thinking?
Logged
Examples can be found at Learning in the Main Site and at the Playground
Pages: [1]   Go Up
Print
Jump to:
