Loading...
Pages: [1]   Go Down
Author Topic: Actuating Lens Project  (Read 878 times)
Offline Offline
Newbie
View Profile
I am new at using Arduino and I need some help with this. I am doing a project involving measuring the focus of an object through a custom built lens. I have a simulink block diagram that gives me a graph on the measure of focus in real time. I would like to send this data to Arduino so that I can analyse the voltage needed for the best focus.
I have used the instrument control toolbox to send this serial data, however it keeps coming up with a timeout error/terminator. Alternatively I tried this code in the command box:
Quote
s=serial('COM1','BaudRate',9600);
fopen(s);
for i = 1:50
  fwrite(s, i, 'uint8', 'sync');
  rx(i) = fread(s, 1);
end
This gave an integer error saying I needed a postitive integer.
Can someone help with a code or point me in the right direction please?
Thank you.
Logged
Netherlands
Online Online
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
You read a byte but do not test if there is one available. The common reaction of the read function is to return -1.
One solution is to read from serial until you do not have a -1.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
God Member
View Profile
"uint" means unsigned int which means a positive integer.  A "uint8"  is a byte with an unsigned integer in it,
which means that the byte can have the range of values 0 to 255.
Whereas a signed  single-byte integer would have a value in the range -128 to +127
Logged
Pages: [1]   Go Up
Print
Jump to:
