Topic: printf on DUE (Read 4477 times) previous topic - next topic
PoohDuino
Hello all,
I want printf support in my Due sketches and
have followed instructions as given at this link: http://playground.arduino.cc/Main/Printf
but I get compile failures ...
    '_FDEV_SETUP_WRITE' was not declared in this scope
    'fdev_setup_stream' was not declared in this scope
I have included stdio.h in the sketch (where the above are defined) but to no avail. If I change the
target board to, say, the Uno then the compile passes. What am I missing?
Thanks.
stimmer
It looks like stdout is already redirected to the programming port UART on the due - try this:
Code: [Select]
#include <stdio.h>
  printf("hello world!\n");
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
PoohDuino
Thank you. You are right it works!
Any ideas on how I can add floating point printf() support?
Thanks.
stimmer
Code: [Select]
#undef printf
#include <stdio.h>
float q=0.1;
  q+=0.1;
  printf("hello world! %f\n",q);
PoohDuino
Yes working again. Thanks.
Where are you getting all this wonderful information from?
Thanks again.
PoohDuino
I have another issue with printf(). I only get output if the string is terminated with "\n"
how do I get output regardless of whether the string is terminated with a NEWLINE?
Where is the DUE printf support documented?
stimmer
fflush(stdout); - this is standard printf behaviour and is not a bug.
There is no proper documentation (yet) as the Due is too new, but there is some documentation here: http://sourceware.org/newlib/ Not all of it will be relevant to the Due.
sohini25
I am unable to get an output with printf() using the code as suggested in earlier post for this message.
#include <stdio.h>
Can you tell me what particular file to include in my arduino sketch to get printf() support. I am using Arduino IDE 1.5.2 with Eclipse.
phr3ak
Anyways, why fdev_setup_stream is unaccessible on due?
