Author Topic: char and integer with serial communication  (Read 165 times)
Hello,
i wan't to send some data with serial communication to a java (netbeans) program.
Buth the data contains a char (or string) and a analoge value (from A0)
now is my question, how i can send this to my java program? when i use
Serial.print('a');
Serial.write(outputValue);
and in my netbeans program, use:
private char myByte
myByte=((char)(input.read()));
it works, buth i can only see the first character of my Analog pin.
when i use something else, like reading a string in stead of a char, i only get numbers.
so the string i converted to numbers.
is there a way how i can send both of them?
best regards
Seattle, WA USA
Seattle, WA USA
Because you are only reading the first byte. Serial.write() of a multibyte value sends multiple bytes.
For ease of debugging, I'd avoid using Serial.write(). Send the outputValue as a string, followed by a delimiter (the cr/lf added by println() is perfect).
Then, read the data until the delimiter arrives, storing it in an array. Then use whatever Java's equivalent of atoi() is to convert the string to a number.
UK
Integer.parseInt(), or Integer.valueOf(), depending whether you wanted an int primitive or an Integer object.
Hello,
i've got it to work, i can receive the string for example : "w: 125",
this is stored in variable : result.
i have also added this code, so i can de substring:
int spacePos = result.indexOf(" ");
number= result.substring(spacePos +1, (spacePos+1)+3);
this means i filter the w: and the space away.
when i print this, it works, i only see the number, buth if i wan't to do something with it, i have to convert it to a integer.
when i use :
number2 = Integer.valueOf(number);
or
number2 = Integer.parseInt(number);
and i print number 2, i don't see anything.
can somebody help me?
best regards
Poole, Dorset, UK
Don't use the String class with the Arduino!.
Mark
how do you mean?, don't send strings with the arduino to my java program?
California
Online Online
Mark
I get the feeling the latest code he posted was Java code.
Seattle, WA USA
Seattle, WA USA
Are those code snippets from your Arduino code, or from your Java code?
In either case, perhaps the good folks at http://snippets-r-us.com can help. We're a little weird here. We need to see ALL of the code.
whow sorry, the code i posted was indeed java  code.
my bad.
 i shall ask it on another forum.
ps: PaulS, i can't open your link, site doesnt work.
best regards
Seattle, WA USA
Seattle, WA USA
Of course it doesn't. That's exactly the point.
UK
I know it's not an Arduino question any more, but you're using the wrong substring function. There are two overloaded function. What you're using takes the three characters following the space, which assumes that the string does actually contain exactly three more characters. If you use this instead, it will take the characters after the separator up to the end of the string:
number= result.substring(spacePos);
If your Integer parsing doesn't produce the value you expect, print the string you parsed and the value you got back and it will probably be obvious why you got the result you did.
