Topic: Joining two programs together (Read 1 time) previous topic - next topic
heffo78
Feb 11, 2013, 07:23 pm Last Edit: Feb 12, 2013, 12:36 pm by heffo78 Reason: 1
Hello all. I am trying to join these to programs together but cant get it working correctly. I keep getting loads of errors.
First program.
Code: [Select]
#include <Adafruit_Fingerprint.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(A0,A1,A2,A3,A4,A5);
#if ARDUINO >= 100
#include <SoftwareSerial.h>
#else
#include <NewSoftSerial.h>
#endif
int getFingerprintIDez();
#if ARDUINO >= 100
SoftwareSerial mySerial(2, 3);
#else
NewSoftSerial mySerial(2, 3);
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
#define redLedPin 12
#define greenLedPin 11
 Serial.println("fingertest");
 finger.begin(57600);
 if (finger.verifyPassword()) {
   Serial.println("Found fingerprint sensor!");
   Serial.println("Did not find fingerprint sensor :(");
   while (1);
 Serial.println("Waiting for valid finger...");
 pinMode(redLedPin, OUTPUT);
 pinMode(greenLedPin, OUTPUT);
 digitalWrite(redLedPin, LOW);
 digitalWrite(greenLedPin, HIGH);
uint8_t getFingerprintID() {
 uint8_t p = finger.getImage();
 switch (p) {
   case FINGERPRINT_OK:
     Serial.println("Image taken");
   case FINGERPRINT_NOFINGER:
     Serial.println("No finger detected");
     return p;
   case FINGERPRINT_PACKETRECIEVEERR:
     Serial.println("Communication error");
     return p;
   case FINGERPRINT_IMAGEFAIL:
     Serial.println("Imaging error");
     return p;
   default:
     Serial.println("Unknown error");
     return p;
 p = finger.image2Tz();
 switch (p) {
     Serial.println("Image converted");
   case FINGERPRINT_IMAGEMESS:
     Serial.println("Image too messy");
     return p;
     return p;
   case FINGERPRINT_FEATUREFAIL:
     Serial.println("Could not find fingerprint features");
     return p;
   case FINGERPRINT_INVALIDIMAGE:
     return p;
   default:
     return p;
 p = finger.fingerFastSearch();
 if (p == FINGERPRINT_OK) {
   Serial.println("Found a print match!");
 } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
   return p;
 } else if (p == FINGERPRINT_NOTFOUND) {
   Serial.println("Did not find a match");
   return p;
   return p;
 Serial.print("Found ID #"); Serial.print(finger.fingerID);
 Serial.print(" with confidence of "); Serial.println(finger.confidence);
int getFingerprintIDez() {
 if (p != FINGERPRINT_OK)  return -1;
 digitalWrite(redLedPin, HIGH);
 digitalWrite(greenLedPin, LOW);
 lcd.print("Hi Enter");
 delay(3000);
 lcd.clear();
 return finger.fingerID;
Second program.
Code: [Select]
#include <Password.h>
#include <Keypad.h>
Password password = Password( "147*" );
const byte ROWS = 4;
const byte COLS = 3;
char keys[ROWS][COLS] = {
 {'1','2','3'},
 {'4','5','6'},
 {'7','8','9'},
 {'*','0',' '}
byte rowPins[ROWS] = {7,6,5,4};
byte colPins[COLS] = {10,9,8};
const int buttonPin = 52;
int buttonState = 0;
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
lcd.begin(16, 2);
keypad.addEventListener(keypadEvent);
keypad.setDebounceTime(250);
void loop(){
keypad.getKey();
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
lcd.clear();
void keypadEvent(KeypadEvent eKey){
switch (keypad.getState()){
case PRESSED:
lcd.print(eKey);
switch (eKey){
case ' ': guessPassword(); break;
default:
password.append(eKey);
void guessPassword(){
if (password.evaluate()){
digitalWrite(redLedPin,HIGH);
digitalWrite(greenLedPin,LOW);
delay(2000);
lcd.print("Hi ");
password.reset();
lcd.print("Enter");
delay(2000);
digitalWrite(12, LOW);
lcd.clear();
else{
digitalWrite(redLedPin,LOW);
lcd.print("GET OUT ");
password.reset();
delay(3000);
lcd.clear();
Any help would be with this problem would be much appreciated. Thank you.
PaulS
Any help will come after you do several things. First, and most important is to fix your post, and post the code properly. Select each program and use the icon with the # symbol to add code tags, to prevent the mangling that has happened with your code.
Second, you must define the requirements for your combined program.
Third, you must post your attempt to combine them.
Finally, I'm pretty sure the compiler was a bit more specific than "loads of errors.". What errors?
CrossRoads
Start by combining the code that goes before void setup,
then combine the code in void setup,
then combine the code in void loop,
then paste in the remaining functions.
Will look something like this - I already deleted the duplicate pin assignments and pinMode/digital writes.
Now its your turn to see if the combo does what you want
(I didn't compile it, so it may have some errors to fix still)
Code: [Select]
#if ARDUINO >= 100
#else
#endif
#include <Keypad.h>
#if ARDUINO >= 100
#else
#endif
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0',' '}
Serial.println("Did not find fingerprint sensor ");
while (1);
lcd.begin(16, 2);
keypad.getKey();
lcd.clear();
switch (p) {
return p;
return p;
return p;
default:
return p;
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
return p;
return p;
return p;
delay(3000);
lcd.clear();
case PRESSED:
lcd.print(eKey);
switch (eKey){
default:
delay(2000);
lcd.print("Hi ");
password.reset();
lcd.print("Enter");
delay(2000);
lcd.clear();
else{
password.reset();
delay(3000);
lcd.clear();
heffo78
Thanks Crossroads. I will test it tomorrow and let you know how it goes. I really appreciate your help. Thank you.
CrossRoads
I don't have all these libraries, so I can't compile it to check errors. The code needs some arranging still, see the notes below, these things will get ya:
>> LiquidCrystal lcd(A0,A1,A2,A3,A4,A5);  this line needs to get moved after the # include lines, and delete the duplicate LiquidCrystal.h
#include <SoftwareSerial.h>  >> probably just one or the other of these
#include <NewSoftSerial.h>  >> probably just one or the other of these
#include <LiquidCrystal.h>  >> duplicate, delete
Good luck.
heffo78
Hi Crossroads. This program is now working. Thanks very much for your help.
This is the code with the few changes.
Thanks again
Code: [Select]
#include <Keypad.h>
#if ARDUINO >= 100
#else
#endif
#if ARDUINO >= 100
#else
#endif
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0',' '}
while (1);
lcd.begin(16, 2);
keypad.getKey();
lcd.clear();
switch (p) {
return p;
return p;
return p;
default:
return p;
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
return p;
return p;
return p;
delay(3000);
lcd.clear();
case PRESSED:
lcd.print(eKey);
switch (eKey){
default:
delay(2000);
lcd.print("Hi ");
password.reset();
lcd.print("Enter");
delay(2000);
lcd.clear();
else{
password.reset();
delay(3000);
lcd.clear();
CrossRoads
apiz
how if i want to dispaly it on LCD using liquidcrystal.h library.. can i get the coding coz im doing same project like this and how to make the password have 3x trials..
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
