Topic: why common emitter configuration is most widely used as an amplifier (Read 5387 times) previous topic - next topic
diaryrashid
hi...
KeithRB
KeithRB
(I would like to point out, that for high-frequency class-C amplifiers, Common-Base is really popular for NPN Bipolar transistors. Of course, the biasing is pretty easy...)
Grumpy_Mike
hi...
Because it shows the highest gain for a given transistor. Common collectors have a voltage gain of 1 and a common base has a low gain.
oric_dan
Because you can easily control a device, like a relay/etc, that needs much higher current
than a microcontroller I/O pin can supply. In general, a 5V pin cannot provide enough
current to even drive a common 5V relay.
In addition, it allows you to control devices that require different voltage levels, such as
a 12V relay.
That's for simple on-off control. If you want to actually amplify "signals", that's something
else again, in which case you want a more reliable amplification-value, see Emitter
degeneration section here,
http://en.wikipedia.org/wiki/Common_emitter
