« on: February 11, 2013, 02:54:46 pm » |
Hello everyone in the Arduino community. Im asking for some help with programing a 3 wheel robot with 2 ultrasonic sensors. The 1st ultrasonic sensor (Parallax) is used as an obstacle avoidance sensor. The second ultrasonic sensor (SR04) is used to check the ground distance so the robot won't fall into a hole in the ground. The problem I'm having is that the Center Distance Reading from the ultrasonic sensor is always reading zero (0) even if there's nothing in front of the ultrasonic sensors. I have used both of these ultrasonic sensors in another project and they both work perfectly so I now there's nothing wrong with the ultrasonic sensors. I will attach the code I'm using for this project. Thank you in advance for your help. #include <AFMotor.h> // Enables the Motor library #include <Servo.h> // Enables the Servo library
Servo PingServo; AF_DCMotor motor1(1); // Motor 1 is connected to the port 1 on the motor shield AF_DCMotor motor2(2); // Motor 2 is connected to the port 2 on the motor shield int minSafeObstacleDist = 11 ; // Minimum distance for ping sensor to know when to turn int pingPin = A0; // Parallax Ping sensor is connected to port A5 int minSafeGroundDist = 2 ; // Minimum distance for ping sensor to know when to turn int TrigPin = A5; // SR04 Ping sensor TrigPin is connected to port A5 int EchoPin = A4; // SR04 Ping sensor EchoPin is connected to port A4 int centerDist, leftDist, rightDist, backDist; // Define variables center, left, right and back distance long duration, inches, cm; // Define variables for Ping sensor
void setup() { PingServo.attach(10); // Servo is attached to pin 10 in the motor shield PingServo.write(90); // Center the Ping sensor (puts it at 90 degrees) motor1.setSpeed(250); // Sets the speed of the first motor. motor2.setSpeed(250); // Sets the speed of the second motor.
Serial.begin(9600); // Enables Serial monitor for debugging purposes Serial.println("Serial test!"); // Test the Serial communication
void AllStop() { motor1.run(RELEASE); // Turns off motor 1 motor2.run(RELEASE); // Turns off motor 2 } void AllForward() { // Makes the robot go forward motor1.run(FORWARD); // Motor 1 goes forward motor2.run(FORWARD); // Motor 2 goes forward Serial.println("Going forward"); // Prints a line in the serial monitor } void turnRight() { // Makes the robot go right motor2.run(BACKWARD); // Turns off motor 2 motor1.run(FORWARD); // Motor 1 goes forward delay(1600); // Time required to turn right (1.6 seconds) Serial.println("Motors going Right"); // Prints a line in the serial monitor } void GoBack(){ // Makes the robot go back motor2.run(BACKWARD); // Motor 2 goes back motor1.run(BACKWARD); // Motor 1 goes back delay(1600); // Time Required to go back (1.6 seconds) Serial.println("Backward"); // Prints a line in the serial monitor } void turnLeft() { // Makes the robot go Left motor2.run(FORWARD); // Motor 2 goes forward motor1.run(BACKWARD); // turns off motor 1 delay(1600); //Time Required to turn left (1.6)Seconds Serial.println("Motors going Left");// Prints a line in the serial monitor } // Starts the loop to decide what to do void loop() { LookAhead(); Serial.print(inches); Serial.println(" inches"); // Prints a line in the serial monitor if((inches >= minSafeObstacleDist) && (inches <= minSafeGroundDist))/* If the inches in front of an object is greater than or equal to the minimum safe distance A (11 inches) and floor distance is less than or equal to the minimum safe distance B, react*/ { AllForward(); // All wheels forward delay(110); // Wait 0.11 seconds }else // If not:
{ AllStop(); // Stop all motors LookAround(); // Check your surroundings for best route if(rightDist > leftDist) // If the right distance is greater than the left distance , turn right { turnRight(); }else if (leftDist > rightDist) // If the left distance is greater than the right distance , turn left { turnLeft(); }else if (leftDist&&rightDist<minSafeObstacleDist) // If the left and right distance is smaller than the min safe distance (11 inch) go back { GoBack(); } } }
unsigned long ping() { pinMode(pingPin, OUTPUT); // Make the Pingpin to output digitalWrite(pingPin, LOW); //Send a low pulse delayMicroseconds(2); // wait for two microseconds digitalWrite(pingPin, HIGH); // Send a high pulse delayMicroseconds(5); // wait for 5 micro seconds digitalWrite(pingPin, LOW); // send a low pulse pinMode(pingPin,INPUT); // switch the Pingpin to input duration = pulseIn(pingPin, HIGH); //listen for echo unsigned long ping(); pinMode(TrigPin, OUTPUT); // Make the Pingpin to output digitalWrite(TrigPin, LOW); //Send a low pulse delayMicroseconds(2); // wait for two microseconds digitalWrite(TrigPin, HIGH); // Send a high pulse delayMicroseconds(5); // wait for 5 micro seconds digitalWrite(TrigPin, LOW); // send a low pulse pinMode(EchoPin,INPUT); // switch the Pingpin to input duration = pulseIn(EchoPin, HIGH); //listen for echo
/*Convert micro seconds to Inches -------------------------------------*/
inches = microsecondsToInches(duration); cm = microsecondsToCentimeters(duration); }
long microsecondsToInches(long microseconds) // converts time to a distance { return microseconds / 74 / 2; } long microsecondsToCentimeters(long microseconds) // converts time to a distance { return microseconds / 29 / 2; }
void LookAhead() { PingServo.write(90);// angle to look forward delay(175); // wait 0.175 seconds ping(); }
void LookAround(){ PingServo.write(180); // 180° angle delay(320); // wait 0.32 seconds ping(); rightDist = inches; //get the right distance PingServo.write(0); // look to the other side delay(620); // wait 0.62 seconds ping(); leftDist = inches; // get the left distance PingServo.write(90); // 90° angle delay(275); // wait 0.275 seconds
// Prints a line in the serial monitor Serial.print("RightDist: "); Serial.println(rightDist); Serial.print("LeftDist: "); Serial.println(leftDist); Serial.print("CenterDist: "); Serial.println(centerDist); }
« Last Edit: February 11, 2013, 05:11:03 pm by CaliforniAduino »
Seattle, WA USA
Seattle, WA USA
« Reply #1 on: February 11, 2013, 02:57:00 pm » |
That is not the way to post code. Modify your post. Select all the code. Select the icon with the # symbol, to add code tags. Save your changes. Then, we'll look at the code.
Deleting the code, opening the IDE, opening the sketch, using Tools + Auto Format, and then posting the fixed up code would be an even better idea.
East Anglia (UK)
Online
May all of your blinks be without delay
« Reply #2 on: February 11, 2013, 03:02:05 pm » |
There will be someone along any minute asking you to highlight your code and put code tags around it by clicking on the # above the smileys to make it easier to read.
Oh, I just did.....
East Anglia (UK)
Online
« Reply #3 on: February 11, 2013, 03:02:47 pm » |
Told you !
UK
Online
« Reply #4 on: February 11, 2013, 03:02:57 pm » |
unsigned long ping() { pinMode(pingPin, OUTPUT); // Make the Pingpin to output digitalWrite(pingPin, LOW); //Send a low pulse delayMicroseconds(2); // wait for two microseconds digitalWrite(pingPin, HIGH); // Send a high pulse delayMicroseconds(5); // wait for 5 micro seconds digitalWrite(pingPin, LOW); // send a low pulse pinMode(pingPin,INPUT); // switch the Pingpin to input duration = pulseIn(pingPin, HIGH); //listen for echo unsigned long ping(); <<<<HERE pinMode(TrigPin, OUTPUT); // Make the Pingpin to output digitalWrite(TrigPin, LOW); //Send a low pulse delayMicroseconds(2); // wait for two microseconds digitalWrite(TrigPin, HIGH); // Send a high pulse delayMicroseconds(5); // wait for 5 micro seconds digitalWrite(TrigPin, LOW); // send a low pulse pinMode(EchoPin,INPUT); // switch the Pingpin to input duration = pulseIn(EchoPin, HIGH); //listen for echo that's an unusual place to put a function prototype. Difficult (for me) to see what you're trying to achieve. If you've got two sensors, on different pins, make a single function with the pin number as parameter.
Netherlands
« Reply #5 on: February 11, 2013, 03:07:14 pm » |
Just wondering, how do you test a cliff avoidance robot ?
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
« Reply #6 on: February 11, 2013, 03:31:02 pm » |
With a very small cliff?
Bob
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Netherlands
« Reply #7 on: February 11, 2013, 03:35:04 pm » |
With a very small cliff? LOL (so not by playing Cliff Richard mp3's
East Anglia (UK)
Online
« Reply #8 on: February 11, 2013, 04:09:41 pm » |
Just wondering, how do you test a cliff avoidance robot ?  You walk backwards in front of it so that can be see it working. No, wait a minute. I have just thought of a snag in my QA plan.
« Reply #9 on: February 11, 2013, 05:01:27 pm » |
// Prints a line in the serial monitor Serial.print("RightDist: "); Serial.println(rightDist); Serial.print("LeftDist: "); Serial.println(leftDist); Serial.print("CenterDist: "); Serial.println(centerDist); } [/quote]
« Last Edit: February 11, 2013, 05:11:51 pm by CaliforniAduino »
East Anglia (UK)
Online
« Reply #10 on: February 11, 2013, 05:11:12 pm » |
Nice try, but still not quite right.
Highlight your code in the post, click the # above the smileys and it will put code tags around your code.
Seattle, WA USA
Seattle, WA USA
« Reply #11 on: February 11, 2013, 05:46:04 pm » |
OP: Doesn't your tab key work properly?
Netherlands
« Reply #12 on: February 12, 2013, 12:52:00 am » |
The problem I'm having is that the Center Distance Reading from the ultrasonic sensor is always reading zero (0) even if there's nothing in front of the ultrasonic sensors. I have used both of these ultrasonic sensors in another project and they both work perfectly so I now there's nothing wrong with the ultrasonic sensors. More serious : - have you tried the sensors in a smallest sketch possible? test them to be sure. best way is to make a copy of your failing sketch and strip it. (This way you might see the code glitch) - do the servo's motors draw too much current causing the sensor to fail? - double check wiring (almost all robots have wring problems at some time)
East Anglia (UK)
Online
« Reply #13 on: February 12, 2013, 01:07:54 am » |
In the middle of your unsigned long ping() function you have the line unsigned long ping(); Are you doing something clever or is that line a mistake ?
UK
Online
« Reply #14 on: February 12, 2013, 02:38:52 am » |
Psst, Bob, reply #4
