Topic: New soft serial buffer maxes at 255 (Read 1 time) previous topic - next topic
instrumentek
Hi; I'm working on a project where I need to receive more than 256 bytes in one buffer from the new soft serial library. I changed the library from the default which helped, but it maxes out at 256 even if I change the library to 512. I am running Teensyduino 2.0++ with arduino 22. I used the memfree program to verify I have lots of RAM left 1.5k  Any help would be appreciated.
here is the library I'm using:
ifndef NewSoftSerial_h
#define NewSoftSerial_h
#include <inttypes.h>
#include "Print.h"
* Definitions
#define _NewSS_MAX_RX_BUFF 512 // RX buffer size
#define _NewSS_VERSION 10 // software version of this library
#ifndef GCC_VERSION
#define GCC_VERSION (__GNUC__ * 10000 + __GNUC_MINOR__ * 100 + __GNUC_PATCHLEVEL__)
#endif
class NewSoftSerial : public Print
private:
  // per object data
  uint8_t _receivePin;
  uint8_t _receiveBitMask;
  volatile uint8_t *_receivePortRegister;
  uint8_t _transmitBitMask;
  volatile uint8_t *_transmitPortRegister;
  uint16_t _rx_delay_centering;
  uint16_t _rx_delay_intrabit;
  uint16_t _rx_delay_stopbit;
  uint16_t _tx_delay;
  uint16_t _buffer_overflow:1;
  uint16_t _inverse_logic:1;
  // static data
  static char _receive_buffer[_NewSS_MAX_RX_BUFF];
  static volatile uint8_t _receive_buffer_tail;
  static volatile uint8_t _receive_buffer_head;
  static NewSoftSerial *active_object;
  // private methods
  void recv();
  bool activate();
  virtual void write(uint8_t byte);
  uint8_t rx_pin_read();
  void tx_pin_write(uint8_t pin_state);
  void setTX(uint8_t transmitPin);
  void setRX(uint8_t receivePin);
  // private static method for timing
  static inline void tunedDelay(uint16_t delay);
public:
  // public methods
  NewSoftSerial(uint8_t receivePin, uint8_t transmitPin, bool inverse_logic = false);
  ~NewSoftSerial();
  void begin(long speed);
  void end();
  int read();
  uint8_t available(void);
  bool active() { return this == active_object; }
  bool overflow() { bool ret = _buffer_overflow; _buffer_overflow = false; return ret; }
  static int library_version() { return _NewSS_VERSION; }
  static void enable_timer0(bool enable);
  void flush();
  // public only for easy access by interrupt handlers
  static inline void handle_interrupt();
// Arduino 0012 workaround
#undef int
#undef char
#undef long
#undef byte
#undef float
#undef abs
#undef round
#endif
PaulS
Why are you waiting until the buffer is full to start reading? Even with a 64 character buffer, you should never let it get full. You can read far faster than data can arrive.
instrumentek
Its bieng displayed on a lcd and is manipulated by several aspects of the program and user interface. I guess i could try stuffing it all into a string. I was hoping i could make some small changes to the library to get it to work.
PaulS
You can't do anything with the data when it is in the serial buffer. You have to read the data and store it somewhere else first. Therefore, making the buffer larger won't help.
If the buffer is filling up, you need to work out handshaking with the sender so that doesn't happen.
instrumentek
Ok, I tried this and am still having issues. I stuff the data into strings as soon as two(my com port) is available. it seems it works better however the data after the 256 buffer starts to break up and does not receive correctly. I have tried several method unable to produce clear data after the buffer. Here is my code:
      while(keyPad != 34 && keyPad != 31)
        c = 0;
dataGather:
        while(two.available() && c <= 160) // gather data for page 1
          a = two.read();
          data1 += a;
          c++;
        while(two.available() && c <= 320) // gather data for page 2
          a = two.read();
          data2 += a;
          c++;
        while(two.available() && c <= 480) // gather data for page 3
          a = two.read();
          data3 += a;
          c++;
        while(two.available() && c <= 640) // gather data for page 4
          a = two.read();
          data4 += a;
          c++;
        delay(20);         // wait for any missed data
        if(two.available())
          goto dataGather;
        Serial.println(data1); // for trouble shooting
        Serial.println(data2); // for trouble shooting
        Serial.println(data3); // for trouble shooting
        Serial.println(data4); // for trouble shooting
        keyPad = 0;
        //----------------------display serial data 1
        if (data1.length() > 0)
          lcd.clearLCD();
          lcd.gotoPosition(0,0);
          Uart.print(data1);
          while(keyPad != 43 && data1.length() >= 160) // wait for user input
            delay(50);
          keyPad = 0;
        //----------------------display serial data 2
        if (data1.length() >= 160)
          lcd.clearLCD();
          Uart.print(data2);
          while(keyPad != 43 && data2.length() >= 160) // wait for user input
            delay(50);
          keyPad = 0;
        //----------------------display serial data 3
        if (data2.length() >= 160)
          lcd.clearLCD();
          Uart.print(data3);
            delay(50);
          keyPad = 0;
        //----------------------display serial data 4
        if (data3.length() >= 160)
          lcd.clearLCD();
          Uart.print(data4);
        //----------------------send serial data out
        data1 = ""; // clear string
        data2 = ""; // clear string
        data3 = ""; // clear string
        data4 = ""; // clear string
         keyPad = 0;
         while(keyPad == 0) // wait for user input as soon as data is sent to port it will respond
        delay(50);
          if (keyPad == 21)
            two.print("Y");
            Uart.print("Y");
          if (keyPad == 22)
            two.print("N");
            Uart.print("N");
          if (keyPad == 26)
            two.print("A");
            Uart.print("A");
          if (keyPad == 27)
            two.print("B");
            Uart.print("B");
          if (keyPad == 28)
            two.print("C");
            Uart.print("C");
          if (keyPad == 29)
            two.print("D");
            Uart.print("D");
          if (keyPad == 1)
            two.print("1");
            Uart.print("1");
          if (keyPad == 2)
            two.print("2");
            Uart.print("2");
          if (keyPad == 3)
            two.print("3");
            Uart.print("3");
          if (keyPad == 4)
            two.print("4");
            Uart.print("4");
          if (keyPad == 5)
            two.print("5");
            Uart.print("5");
          if (keyPad == 6)
            two.print("6");
            Uart.print("6");
          if (keyPad == 7)
            two.print("7");
            Uart.print("7");
          if (keyPad == 8)
            two.print("8");
            Uart.print("8");
          if (keyPad == 9)
            two.print("9");
            Uart.print("9");
          if (keyPad == 10)
            two.print("10");
            Uart.print("10");
          if (keyPad == 32 || keyPad == 44)
            two.print("-");
            Uart.print("-");
          if (keyPad == 30)
            two.print("\r");
            Uart.print("enter");
my received data looks like this (after "B - DELT" is over 256):
This utility allows a technican to describe the dial face to the meter.
The meter uses these values to determine the correct needle placement.
The OUTER set
of numbers on the dial is the MAIN scale (#1)
The INNER set of numbers on the dial is the DELTA, WOB or 2nd scale
The Main scale is always used in NORMAL MODE
What is the second scale function? [Pick one letter from the list]
    A - Normal mode w/ alternate calibration eg: #of lines or English/Metric
    B - Delt
a mo- ransivlae ightod   -igOnt e - xtsetiresefling
Foornfat culhener' Mal
PaulS
Get rid of the labels and goto statements, then we'll talk.
instrumentek
done, same thing.
        c = 0;
          a = two.read();
          data1 += a;
          c++;
          a = two.read();
          data2 += a;
          c++;
          a = two.read();
          data3 += a;
          c++;
          a = two.read();
          data4 += a;
          c++;
        keyPad = 0;
          lcd.clearLCD();
          Uart.print(data1);
            delay(50);
          keyPad = 0;
          lcd.clearLCD();
          Uart.print(data2);
            delay(50);
          keyPad = 0;
          lcd.clearLCD();
          Uart.print(data3);
            delay(50);
          keyPad = 0;
          lcd.clearLCD();
          Uart.print(data4);
         keyPad = 0;
        delay(50);
          if (keyPad == 21)
            two.print("Y");
            Uart.print("Y");
          if (keyPad == 22)
            two.print("N");
            Uart.print("N");
          if (keyPad == 26)
            two.print("A");
            Uart.print("A");
          if (keyPad == 27)
            two.print("B");
            Uart.print("B");
          if (keyPad == 28)
            two.print("C");
            Uart.print("C");
          if (keyPad == 29)
            two.print("D");
            Uart.print("D");
          if (keyPad == 1)
            two.print("1");
            Uart.print("1");
          if (keyPad == 2)
            two.print("2");
            Uart.print("2");
          if (keyPad == 3)
            two.print("3");
            Uart.print("3");
          if (keyPad == 4)
            two.print("4");
            Uart.print("4");
          if (keyPad == 5)
            two.print("5");
            Uart.print("5");
          if (keyPad == 6)
            two.print("6");
            Uart.print("6");
          if (keyPad == 7)
            two.print("7");
            Uart.print("7");
          if (keyPad == 8)
            two.print("8");
            Uart.print("8");
          if (keyPad == 9)
            two.print("9");
            Uart.print("9");
          if (keyPad == 10)
            two.print("10");
            Uart.print("10");
            two.print("-");
            Uart.print("-");
          if (keyPad == 30)
            two.print("\r");
KeithRB
I might have missed it, but what is data1, et al? If they are Strings, that might be your problem since you are doing a lot of malloc'ing and free'ing behind the scenes. Better to roll your own char arrays.
instrumentek
Sorry, my whole program is way to long to post. Can you provide an example?
unsigned long time = 0;
    long injectorLow;
    long injectorHigh;
    long injectorMid;
    int curOutInputRaw;
    byte b = 0;
    int c = 0;
    byte d = 99;
    char a;
    String data1;
    String data2;
    String data3;
    String data4;
    char order1[] = {
      'N','N','N','Y','A','N'                    };
    long order2[] = {
      -17750,35586,-6672,6672                    };
    byte manuel = 0;
PeterH
In that case most of the sketch is probably not relevant to the problem. Extract the relevant parts into a simple sketch that just demonstrates the problem, and post that. (Make sure the sketch does actually compile and run and demonstrates the problem.)
I only provide help via the forum - please do not contact me for private consultancy.
UKHeliBob
You can attach a file to a post.  Look at Additional Options...  bottom/left of the edit window.  That gets round the size limitation on posting long code.
KeithRB
char data1[256];
int data1_idx = 0;
int c=0;
          a = two.read();
          data1[data1_idx++] = a;
          data1[data1_idx] = '\0'; //Put in nul
          if (data1_idx == 255)
                  //Error! Do something!
          c++;
PaulS
The two.available() condition may never be true. Or, it may not be true before keyPad takes on one of the non-proscribed values.
Where is keyPad assigned a value? What do the values 34 and 31 mean?
What is connected to the instance called two? Are you, somewhere outside the code you've posted so far, waiting for two.available() to return a value greater than 0?
instrumentek
hey, i made a small sketch that does not use keypad. still has same issue i'm going to post it shortly. 31 and 34 are the exit keys. your last question i will post the complete sketch demonstrating this issue shortly
instrumentek
Thanks for help so far, I made this program as you suggested. it has the same issue the data output on the longer streams is garbled
#include <NewSoftSerial.h>
#include <serialGLCD.h>
int mode = 0;
byte b = 0;
int c = 0;
char a;
String data1;
String data2;
String data3;
String data4;
HardwareSerial Uart = HardwareSerial();
serialGLCD lcd;
  Uart.begin(115200); // for display
  lcd.resetLCD();
  pinMode(9,OUTPUT); // serial power
  digitalWrite(9,0); // Serial Power
  // ____________________________________________________________Weight Gauge____________________________
weightGauge:
  lcd.clearLCD();
  NewSoftSerial two(27, 7);
  two.begin(19200);
  digitalWrite(9, 1);
  mode = 0;
  Uart.print("turn on gauge");  // wait to start device
  delay(5000);
  two.print("N"); // Type the capital letters NOI to start
  delay(10);
  two.print("O"); // Type the capital letters NOI to start
  delay(10);
  two.print("I"); // Type the capital letters NOI to start
  delay(10);
  while (mode < 5) // loop for data gather to lcd after device ready
    c = 0;
    mode = mode+1;
    delay(2000);
    if (mode == 1)
      two.print("N"); // after data is sent device will respond
    if (mode == 2)
    if (mode == 3)
    if (mode == 4)
      two.print("Y"); // after data is sent device will respond
      a = two.read();
      data1 += a;
      c++;
      a = two.read();
      data2 += a;
      c++;
      a = two.read();
      data3 += a;
      c++;
      a = two.read();
      data4 += a;
      c++;
    Serial.print("data1 = ");
    Serial.print("data2 = ");
    Serial.print("data3 = ");
    Serial.print("data4 = ");
      lcd.clearLCD();
      Uart.print(data1);
      delay(3000);
      lcd.clearLCD();
      Uart.print(data2);
      delay(3000);
      lcd.clearLCD();
      Uart.print(data3);
      delay(3000);
      lcd.clearLCD();
      Uart.print(data4);
      delay(3000);
