Loading...
Pages: [1]   Go Down
Author Topic: client.println output won't show in serial window  (Read 143 times)
Offline Offline
Newbie
View Profile
When I try to use this code below, I just want to see the result of my http request
through the serial monitor. Unfortunately, client.println is not displaying results.
Any reason why?
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "username";          //  your network SSID (name)
char pass[] = "password";   // your network password
int status = WL_IDLE_STATUS;
char servername[]="www.arduino.cc";  // remote server we will connect to
WiFiClient client;
  Serial.println("Attempting to connect to WPA network...");
  Serial.print("SSID: ");
  Serial.println(ssid);
  status = WiFi.begin(ssid, pass);
  if ( status != WL_CONNECTED) {
    Serial.println("Couldn't get a wifi connection");
    // don't do anything else:
    while(true);
  else {
    Serial.println("Connected to wifi");
    Serial.println("\nStarting connection...");
    // if you get a connection, report back via serial:
    if (client.connect(servername, 80)) {
      Serial.println("connected");
      // Make a HTTP request:
      // byte joe[2000];
    client.println("GET /latest.txt HTTP/1.1");
    client.println("Host: www.arduino.cc");
    client.println("User-Agent: arduino-ethernet");
    client.println("Connection: close");
    client.println();
      while (client.available()) {
        char c = client.read();
        Serial.write(c);
        client.println();
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Perhaps because the Serial Monitor is not a client. Serial.print() and Serial.println() are used to send data to the Serial Monitor, not client.print() or client.println().
Logged
Offline Offline
Newbie
View Profile
o boy... I feel really dumb right now haha. Thanks though. What can i use as a client? -suggestions
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
Do you want to see the request you are sending or the response from the server? If it is the server response you want to see, then you are not waiting for the response. This is the basic code. The server will close the connection when finished sending packets. After you send the request, this gets the response.
Code:
 while(client.connected()) {
        Serial.write(c);
  client.stop();
This needs a timeout in that loop to prevent a lockup if the connection breaks.
Logged
Offline Offline
Newbie
View Profile
apparently, there are just problems between the wifi shield and mac OSX. Thanks for the help
Logged
Pages: [1]   Go Up
Print
Jump to:
