Loading...
Pages: [1]   Go Down
Author Topic: Relay Shield Code Issues  (Read 101 times)
Offline Offline
Newbie
View Profile
My project is a Jeopardy style table that has 4 switches. When one switch is pressed, it lights up its corresponding light and disables the other switches for 5 seconds, after which it returns back to a waiting state. Here is the code:
Code:
//Pressing 1 switch blocks the others and lights up a light through a relay for 5 seconds
//4 switches and 4 corresponding relays
// These are constant because it makes the code run faster on the microcontroller.  The compiler more or less does this.
const byte switchA = 2;
const byte switchB = 3;
const byte switchC = 4;
const byte switchD = 5;
const byte relayA = 6;
const byte relayB = 7;
const byte relayC = 8;
const byte relayD = 9;
// enumerated states so that things don't die immediately...
enum state_t { A = 1, B = 2, C = 3, D = 4, Wait = 5 };
void setup(){
  pinMode (switchA, INPUT_PULLUP);
  pinMode (switchB, INPUT_PULLUP);
  pinMode (switchC, INPUT_PULLUP);
  pinMode (switchD, INPUT_PULLUP);
  pinMode (relayA, OUTPUT);
  pinMode (relayB, OUTPUT);
  pinMode (relayC, OUTPUT);
  pinMode (relayD, OUTPUT);
  static state_t state = Wait;
  // Variables with static are initialized the first time a function runs.
  // These are non-global so that CS professors won't complain.
  switch(state) {
    case A:
      digitalWrite(relayA,HIGH);
      digitalWrite(relayB,LOW);
      digitalWrite(relayC,LOW);
      digitalWrite(relayD,LOW);
      delay(5000);
      digitalWrite(relayA,LOW);
      state = Wait;
    case B:
      digitalWrite(relayB,HIGH);
      delay(5000);
      state = Wait;
    case C:
      digitalWrite(relayC,HIGH);
      delay(5000);
      state = Wait;
    case D:
      digitalWrite(relayD,HIGH);
      delay(5000);
      state = Wait;
    case Wait:
      if (!digitalRead(switchA)) {
        state = A;
      } else if (!digitalRead(switchB)) {
state = B;
      } else if (!digitalRead(switchC)) {
state = C;
      } else if (!digitalRead(switchD)) {
state = D;
state = Wait;
    default:
      state = Wait;
My friend helped me program it as a FSM but when I tested it the relay for case A immediately activated when power was applied. It may be a hardware issue but can anybody see any issues with the programming itself? Thank you.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
The code looks OK.
My guess is that the Switch A pin is shorted to ground.
If you hold down B does the relay for B trigger after A has been on for five seconds?  That would help prove that the rest of the hardware was working as expected.
Logged
Offline Offline
Newbie
View Profile
I'm not sure yet. I only just plugged it in to power and heard the click and tested relayA. I'll go test the other ones and report back.
Logged
Pages: [1]   Go Up
Print
Jump to:
