Pages: [1] 2   Go Down
Author Topic: Can't write multiple pins HIGH why?  (Read 543 times)
Gales Ferry, CT
Always thinking
Here is my code:
int ledI = 13;
int ledL = 12;
int ledO = 11;
int ledV = 10;
int ledE = 9;
int ledY = 8;
int ledo = 7;
int ledU = 6;
  pinMode(ledI, OUTPUT);
  pinMode(ledL, OUTPUT);
  pinMode(ledO, OUTPUT);
  pinMode(ledV, OUTPUT);
  pinMode(ledE, OUTPUT);
  pinMode(ledY, OUTPUT);
  pinMode(ledo, OUTPUT);
  pinMode(ledU, OUTPUT);
// the loop routine runs over and over again forever:
  delay(100);
  digitalWrite(ledI, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(ledI, LOW);    // turn the LED off by making the voltage LOW
  delay(3000);               // wait for a second
  digitalWrite(ledL, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(ledL, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(ledO, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(ledO, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(ledV, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(ledV, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(ledE, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(ledE, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(ledY, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(ledY, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(ledo, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(ledo, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(ledU, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(ledU, LOW);    // turn the LED off by making the voltage LOW
I then wanted the led I, L, O, V, E, Y, o, U to write high and tried to use digitalWrite but it errored on me. What should I use in its place?
Thanks
Patience.....
Grand Blanc, MI, USA
Online Online
"We're a proud service of the Lost Electricity Reclamation Agency"
What is the error? It compiles fine for me.
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Seattle, WA USA
Online Online
Seattle, WA USA
Your wife/girlfriend/whatever is going to fall asleep waiting for the end of that cycle. Why such a long delay between changes?
Online Online
Perhaps the focus is not completely on the microcontroller, between delays.
Unless there is a typo I am missing, your code should run fine. I agree though, your delays are really long. lol.
Did you really intend it to take 30 seconds to cycle through one loop?
Gales Ferry, CT
Always thinking
Hey the delay is just the default blink I was going to slim it down but was halted in the code development! My wife would fall asleep LOL
The last two lines is what I was having issues with. Dunno why I didn't copy them in first!
int ledI = 13;
int ledL = 12;
int ledO = 11;
int ledV = 10;
int ledE = 9;
int ledY = 8;
int ledo = 7;
int ledU = 6;
  delay(100);
  digitalWrite(ledI, ledL, ledO, ledV, ledE, ledY, ledo, ledU, HIGH);    // turn the LED off by making the voltage LOW
  digitalWrite(ledI, ledL, ledO, ledV, ledE, ledY, ledo, ledU, LOW);    // turn the LED off by making the voltage LOW
Patience.....
Ahhh... lol. Yeah, you can't do that. Just put each one on it's own line without any delays in between. It will happen so fast, that it will appear to all turn on at once. The human eye couldn't capture it.
Also, if they are all using the 8 bits (you have 8 letters) of one port, you could just do this:
PORTn = 0xFF and that would turn on all bits at once. n = whatever port they are on. PORTD is pins 0-7. But you will lose your serial port. If you aren't using it, no big deal. It's the only full 8-bit port available.
However, my first suggestion would happen so fast, the results will look the same.
« Last Edit: February 11, 2013, 08:45:32 pm by Retroplayer » Logged
Gales Ferry, CT
Always thinking
Awesome thanks!  smiley-eek
Patience.....
Gales Ferry, CT
Always thinking
Retro
I deleted all delays and it blinked for a tiny fraction of a second but was almost unnoticeable so I deleted the delay after the low and it blinks left to right really fast which is not what I want. Thoughts?
int ledI = 13;
int ledL = 12;
int ledO = 11;
int ledV = 10;
int ledE = 9;
int ledY = 8;
int ledo = 7;
int ledU = 6;
  delay(500);               // wait for a second
  delay(50);
  delay(50);
  delay(50);
  delay(50);
  delay(50);
  delay(50);
  delay(50);
  delay(50);
Patience.....
Lost Wages
I'm going to take a wild guess.
Each pin has multiple LEDs on it that spell out each letter?
Remember that the Arduino pins are only rated for 40mA max.  If you are trying to drive a number of LEDs in parallel then your poor Arduino just can't keep up.  If you are driving them in series, then the voltage across the string would have to be much larger than 5V.
If, indeed, the LEDs are in parallel be sure that each LED has its own individual current-limiting resistor and place an NPN transistor from ground to the cathodes of the LEDs and then place the current-limiting resistors from the anode to +5V.  Use a 10k resistor from the each Arduino pin to the base of each transistor.
With 330 ohm resistors, each LED will draw about 10mA.  So a 2n2222 should be fine. It has a max current of 200mA so it would drive 20 LEDs.
I hope that this helps but it is a wild guess.
« Last Edit: February 11, 2013, 09:13:26 pm by MaJiG » Logged
Gales Ferry, CT
Always thinking
I put one LED to one pin.
https://docs.google.com/file/d/0Bx_sFejXsULPZm9BMFloRW5UWjQ/edit?usp=sharing
Patience.....
Lost Wages
Your resistors are not in the breadboard correctly.
From the Arduino pin to one end of the resistor
The other end should be in another row, with the (looks like) anodode of the LED
The other end of the LED should go to ground
These LEDs are probably burned, so try new ones
Gales Ferry, CT
Always thinking
The LED's are working just fine what did I do?!  smiley-money
Patience.....
Lost Wages
If you move each wire from an Arduino pin one breadboard row to the left and the move the near end of the resistor over to the row with the wire, you'll be gold.  Of course the left-most will need a custom swap, but you get the idea...
Gales Ferry, CT
Always thinking
Ok I see what I did... put each resistor on the same line as the led so essentially muting the resistor. This correct?  smiley-eek-blue
Patience.....
Pages: [1] 2   Go Up
