Topic: [Solved] Unable to connect to web server, can't seem to find the problem (Read 1 time) previous topic - next topic
JackSac67
I want to adjust the background color of a web page by adjusting a pot, but I can't for the life of me figure out why I'm not able to connect to the web server. I just get "Unable to connect to server" in my browser. Here's the code, help point me towards anything missing or that needs revision please.
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x50, 0x9A };
byte ip[] = { 10, 0, 1, 8 };
EthernetServer server(8010);
 pinMode(A3, INPUT);
 Ethernet.begin(mac, ip);
 server.begin();
 int val = analogRead(A3);    //read pot analog input
 if (client) {
   boolean current_line_is_blank = true;
   while (client.connected()) {
     if (client.available()) {
       char c = client.read();
       int color = map(val, 0, 1023, 0x000000, 0xFFFFFF);    //map the analogRead() values to HEX values for HTML colors
       Serial.println(val);    //print em'
       Serial.println(color);
       if (c == '\n' && current_line_is_blank) {
         client.println("HTTP/1.1 200 OK");    //standard HTTP header, a little HTML too
         client.println("Content-Type: text/html");
         client.println();
         client.println("<html><head><title>");
         client.println("Change pot to change color!");
         client.println("</title><body bgcolor=");
         client.print(color);
         client.println(">");
         client.println("<h1>Hello, World</h1>");
         client.println();
         client.print("</body></html>");
       if (c == '\n') {
       } else if (c != '\r') {
         current_line_is_blank = false;
   delay(1);
   client.stop();
SurferTim
#1
Feb 12, 2013, 01:09 pm Last Edit: Feb 12, 2013, 01:28 pm by SurferTim Reason: 1
Is this ip in the subnet of your localnet?
Code: [Select]
Are you using the port with it in your web browser?
http://10.0.1.8:8010
edit: Eye Korretd mi spelin misteak.  ;)
PaulS
Quote
You misspelled "Korrectd".  8)
PaulS
These two statements:
Code: [Select]
  pinMode(A3, INPUT);
and
Code: [Select]
do not go together.
Analog pins are input only. They can not be set to output, nor do they have pullup resistors. So, the pinMode() command is completely unaware that they exist. You are diddling with the digital nature of that pin, which you don''t use. So, don't diddle with it.
JackSac67
Code: [Select]
Yes and yes
Quote
Code: [Select]
  pinMode(A3, INPUT);
and
Code: [Select]
do not go together.
Right, that was my bad. But how would this have an effect on my problem?
SurferTim
Can you ping the Arduino from your computer?
Do you have a uSD card in the slot on the shield? If so, remove it and try again.
Try adding this to your setup() function. Maybe something with the SPI isn't working.
Code: [Select]
  Serial.print("IP = ");
  Serial.println(Ethernet.localIP());
  server.begin();
Does it show "IP = 10.0.1.8"? If it shows anything else, like "IP = 0.0.0.0", it may not be working.
JackSac67
Never mind, I've fixed it. Turns out my router was reset with an ethernet connection already established on one of its ethernet ports and it screwed up the whole system. Just had to unplug and plug back in.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
