Loading...
Pages: 1 [2]   Go Down
Author Topic: The ants come marching in (and release magic smoke)  (Read 646 times)
Denmark
Offline Offline
Full Member
New on the Arduino platform...
View Profile
WWW
The places the ants were stuck has nothing to do with the problem at all. That solder joint got cold over time (thermal expansion and contracting) over time which leads to a failed solder joint like that. Also if the component soldered in that joint has some mass, the vibration from you opening and closing of the door makes it shake loose over time, rendering you with the same problem.
This time it was not the fault of the bugs...
// Per.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
It may also have touched the metal casing?  Looks like a high-current discharge caused the blackening.  The leads on that
board have not been cropped short, i.e. poor build quality.   Ants are usually associated with high voltage flashover in the mains
section of an appliance - they are one reason why mains wiring should never run close to sensitive low-voltage circuitry!
Logged
London
Offline Offline
Sr. Member
View Profile
It's the superconducting ant spit that does it...
ANTimatter...
Logged
Offline Offline
Full Member
W9LZ
View Profile
Of course they're electromagnetic....ANTennas.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
