I'm working on a home automation system using a Beaglebone, an Arduino Uno, and several home-built arduino clones.
My issue is with my Uno and the I2C setup I'm using.
I've written code to have my Uno act as a I2C recieving slave. I'm trying to figure out why the following code doesn't work.
#include <Wire.h>
Wire.begin(4);
Wire.onReceive(receiveEvent);
//Serial.println("Debug Spot 1");
delay(100);
void receiveEvent(int howMany)
byte data[howMany];
byte ELC = 0xFF;
byte off = 0xA0;
byte on = 0xA1;
byte kitchenLights = 0x01;
//Serial.println("Debug Spot 2");
while(Wire.available())
for (int i=0; i <= howMany; i++){
data[i] = Wire.read();
for (int i=0; i < howMany; i++) {
if (data[i] == ELC){
Serial.println("Aborting...");
if (data[0] == kitchenLights) {
Serial.print("Kitchen Lighting selected. Action: ");
if (data[1] == on) { Serial.println("Turn On"); }
if (data[1] == off) { Serial.println("Turn Off"); }
With this code, everything appears to work correctly (i.e. I get the first debug line printed when it's not commented out, and the Uno appears on the bus at 0x04), until I send data to the Uno. When I do that, the Uno freezes, and locks the entire bus. I've done troubleshooting, and I've tracked the bug to the following snippet:
If I change the
0 to an
i, it works perfectly, but doing this limits to only using 0x01 in the first byte I send to the Uno.
While I can live with the limitation, I'm a bit stumped as to why the original code causes the Uno to hang.
Any ideas?
