Loading...
Pages: [1] 2 3 4   Go Down
Author Topic: solar tracker using RTC  (Read 1329 times)
DELHI
Offline Offline
Full Member
View Profile
Dear all,
i just wanted to create algorithm to track the sun using Real time Clock. I need your help for develop code and run it successfully.
component i am going to use.
1)arduino uno board
2)DS1307
3)linear actuator
concept goes like this
usually sun track start from  morning 8AM to 6PM.
 1)
as per research made SPA algorithm code will not work on Arduino board.From where i calculated the sun elevation angle
2)using real time clock i can get accurate time . and how can impliment this to get position
IS it possible to calculate sun elevation using above component
Logged
AMPS
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
You can do a two axis tracker using at most four LDRs, a couple of op-amps and a couple of H-bridges.
All the RTC needs to do is return the rig to "home" just before dawn.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
East Anglia (UK)
Offline Offline
Edison Member
May all of your blinks be without delay
View Profile
http://bit.ly/11Ddm97
Logged
Offline Offline
God Member
View Profile
It is totally possible to calculate the sun's position at any instant,  as long as you know the time and your location.
I don't understand your claim that the calculation cannot be made on an arduino.
You can follow the sun this way,   without any light sensor at all,  if you really wanted to.   The obstacle
would be in having an accurate and persistently calibrated position actuator,   which is not straightforward
to achieve.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
What research? Link?
Logged
DELHI
Offline Offline
Full Member
View Profile
This mean to say  i have spa algorithm it does work over arduino board, since it support double precision floating point.
Logged
AMPS
DELHI
Offline Offline
Full Member
View Profile
please let me know how you calculate sun position depend on time and date.
to achieve.
Logged
AMPS
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I assume you know where you are?
http://williams.best.vwh.net/sunrise_sunset_algorithm.htm
Logged
Dee Why NSW
Offline Offline
God Member
View Profile
I don't know what an SPA algorithm is, and it's not clear whether it will work on an Arduino or not. What is even less clear is why you would need double precision anyway. If you really need to do this, rather than  use LDRs, Jan Meeus or Peter Duffet-Smith will tell you all you need to know. You may also find a lookup table will suffice. Once you have settled on all that computing stuff, all you need to do is sort out how you handle the mechanical accuracy stuff.
Logged
Tasmania - Australia
Offline Offline
Sr. Member
View Profile
WWW
Watching with interest.
I will be coding up tracking facilities onto my Arduino to move a solar array here at my home, and have a small scale mock up of the construction.
The hole is dug, the concrete is ready to be mixed up for the tower.
I have hot dipped galvanised 2 metre sections of triangle tower to mount the tracker on.
I'll be using a single 36VDC linear ram drive with a extension of 600mm, normally used for satellite dish position.
I intend to use my know location and knowing the time to point the solar array to the correct position, without the use of light sensors.
I already have the Arduino getting UTC from a network time server as part of my whole renewable energy system.
Here is a link to some information to generate some further interest, http://en.wikipedia.org/wiki/Sun_path
I guess SPA is Sun Path Algorithm, I see no problem that the Arduino can calculate exactly what the position needs to be.
My renewable system as it is at present is viewable on the web in my signature.
Quote
Well, isn't that neat, I like that.
Paul
« Last Edit: February 15, 2013, 01:01:45 am by rockwallaby » Logged
Renewable Energy Monitor Project http://paulalting.com/hydrosolar.php     No, I don't really suffer from insanity, I enjoy it.     I do it with Eclipse IDE and Jantje's AVR plugin http://baeyens.it/eclipse/
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Single precision float should be adequate for these calculations. However as Nick_Pyner said, a simple table could well suffice. Consider holding data for 365 days (sunrise and sunset) at 4 bytes each, that would be:
Code:
365*4*2 = 2920 bytes
Stored in program memory, that is probably less than the library code that would be pulled in to do the sine/cosine/asin/acos calculations anyway.
There would be a slight discrepancy due to the "leap year" factor after a year, but hardly enough to really worry a solar array.
If you need more data (more than sunrise/sunset) you can probably still do it to reasonable accuracy with fairly simple code.
Google: arduino solar panel tracking
I got over 2 million hits.
Logged
DELHI
Offline Offline
Full Member
View Profile
http://www.nrel.gov/midc/spa/
I HAVE LINKED ATTACHED ABOVE .If you put latitude and longitude u will get elevation angle for particular date,time etc
Logged
AMPS
DELHI
Offline Offline
Full Member
View Profile
i wanna do simple single axis.
how should i calculate sun elevation angle??
Logged
AMPS
Global Moderator
UK
Online Online
Brattain Member
View Profile
It will take some work to get the constant tables into program memory, but without trying, it's a little trite to say "it won't work on an Arduino".
It would almost certainly work unmodified on a Due.
sp. "want to"
Logged
DELHI
Offline Offline
Full Member
View Profile
whole idea is i wanna do with cheaper solution , I wanna use only rtc, linear actuator  and arduino board  for the project.
If i am using above component is it possible to it??
if yes how can i do it??
how can calculate sun elevation angle??
i don't have any sensor to locate and control the position.
to achieve.
Logged
AMPS
Pages: [1] 2 3 4   Go Up
Print
Jump to:
