Topic: solar tracker using RTC (Read 11192 times) previous topic - next topic
AWOL
Quote
but would be ridiculously over the top if we're just trying to point a solar panel in the right general direction.
Couldn't agree more.
See earlier discussions regarding H-bridges, heliotropes and CdS LDRs.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
AMPS-N
Can some one guideline how can i calculate the sun elevation angle.
please share me link if possible.
if someone has already achieved using RTC share code.
AMPS
PeterH
How accurately are you trying to calculate it?
I only provide help via the forum - please do not contact me for private consultancy.
Nick_Pyner
You will probably get all you want from the Cerebral Meltdown forum. It seems to specialise in this sort of thing.
dc42
#34
Feb 16, 2013, 04:49 pm Last Edit: Feb 17, 2013, 07:52 pm by dc42 Reason: 1
Have you tried copying the code you linked to at http://www.nrel.gov/midc/spa/ and changing all instances of 'double' to 'float'?
[EDIT: as AWOL says, you don't need to change 'double' to float, however on the Arduino I believe they are both the same i.e. 32 bits.]
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
AWOL
You don't need to change doubles to floats. I only did it because I used a platform where doubles are 64 bit, and I wanted to compare performance.
It works fine on a Due, but as-is, uses too much RAM for a Mega.
solar123
Hello All,
I am relatively new to the arduino.. I am currently pursuing a solar tracker as a project for my final year of engineering...
It is a single axis system..
We am planning on having 2 systems for tracking
1) this is based on the solar position algorithm(SPA) released by NREL
2) A system based on 2 LDR's
As it is single axis all i need is the sun's elevation angle.
I plan on using the arduino DUE and i wanted to know if the DUE would be able to handle SPA code by NREL ??
Also as ours is a concentrator based system the dish is large and what sort of drive should i use for the DC motor ??
Any help would be much appreciated.
Thank you.
AWOL
#37
Feb 26, 2013, 10:37 am Last Edit: Feb 26, 2013, 10:39 am by AWOL Reason: 1
Quote
Have you read this thread?
(give your keyboard a shake - your question-mark key looks like it is sticky)
dc42
That code has a number of large arrays of constants, but only uses small arrays of variables. I think even a standard Arduino could handle it if you move the tables of constants to PROGMEM.
AWOL
Not so sure about that - there are also some large variable arrays, too much even for a Mega.
The advantage of the Due is that it maintains 64 bit doubles.
dc42
Can you point out where in the code those arrays are? I'm sure you're right, but I only found variable arrays with ~6 elements.
AWOL
I'm sorry - I think you're right, it may well be possible.
I did start to look at moving them to ROM on a Mega, then remembered Massimo had kindly given me a Due, which also made verification easier.
solar123
thank you.
the DUE has an ARM core and the controller it uses is the AT91SAM3X8E.
As per the data sheet the above controller has a real time clock so i wanted to use this on board rtc with the SPA program.
I will fix the latitude and longitude the program must be able to get the date and time from the rtc on a regular basis for tracking purposes.
How can i do this ?
AWOL
Is the RTC supported yet?
You could start there, if it isn't.
solar123
this is what i found for the rtc on the due.
https://github.com/MarkusLange/Arduino-Due-RTC-Library
could you tell me if the above is working ?
Also how to use this with the SPA ?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
