Lamezia Terme
Offline
Shannon Member
Le domande di chi vuol imparare rappresentano la sua sete di sapere
« Reply #60 on: February 17, 2013, 03:59:09 pm » |
infatti sono sbagliate, usa queste due: mega3208.name=ATmega328P 8MHz internal clock mega3208.upload.protocol=arduino mega3208.upload.maximum_size=32768 mega3208.upload.speed=115200 mega3208.bootloader.low_fuses=0xe2 mega3208.bootloader.high_fuses=0xdf mega3208.bootloader.extended_fuses=0x07 mega3208.bootloader.path=optiboot mega3208.bootloader.file=optiboot_atmega328.hex mega3208.bootloader.unlock_bits=0x3F mega3208.bootloader.lock_bits=0x0F mega3208.build.mcu=atmega328p mega3208.build.f_cpu=8000000L mega3208.build.core=arduino mega3208.build.variant=standard
mega3201.name=ATmega328P 1MHz internal clock mega3201.upload.protocol=arduino mega3201.upload.maximum_size=32768 mega3201.upload.speed=115200 mega3201.bootloader.low_fuses=0x62 mega3201.bootloader.high_fuses=0xdf mega3201.bootloader.extended_fuses=0x07 mega3201.bootloader.path=optiboot mega3201.bootloader.file=optiboot_atmega328.hex mega3201.bootloader.unlock_bits=0x3F mega3201.bootloader.lock_bits=0x0F mega3201.build.mcu=atmega328p mega3201.build.f_cpu=1000000L mega3201.build.core=arduino mega3201.build.variant=standard
Logged
Forum Moderator
Italy
Offline
Brattain Member
Don't know what I do
« Reply #61 on: February 18, 2013, 01:40:51 am » |
Difatti il problema dovrebbe nascere dalla mancanza di "variant", ossia nelle ultime versioni dell'IDE oltre al core va specificata la variante, ossia il file che definisce i pin del microcontrollore.
Logged
Lamezia Terme
Offline
Shannon Member
« Reply #62 on: February 18, 2013, 04:33:01 am » |
E' sbagliato anche il protocollo....
Logged
Forum Moderator
Italy
Offline
Brattain Member
« Reply #63 on: February 18, 2013, 04:49:55 am » |
Cosa intendi per "protocol"? Quale board stai analizzando?
Logged
Lamezia Terme
Offline
Shannon Member
« Reply #64 on: February 18, 2013, 04:51:20 am » |
Cosa intendi per "protocol"? Quale board stai analizzando? quella che aveva postato lui, non era solo la mancanza di variant, era sbagliato anche il valore dato a protocol
Logged
Forum Moderator
Italy
Offline
Brattain Member
« Reply #65 on: February 18, 2013, 05:29:43 am » |
Ok
Logged
Latina
Offline
Jr. Member
« Reply #66 on: February 18, 2013, 10:30:46 am » |
amici ,
tra un po torno a casa e verifico il tutto .
a.
Logged
Latina
Offline
Jr. Member
« Reply #67 on: February 18, 2013, 01:43:42 pm » |
buona sera a tutti .
ho copiato il listato
adesso messaggi strani non ne da da solo questo
Dimensione del file binario dello sketch: 1.046 bytes (su un massimo di 32.768 bytes) avrdude: stk500_getsync(): not in sync: resp=0x00
il led ancora non lampeggia . che potrebbe essere ?
Logged
Latina
Offline
Jr. Member
« Reply #68 on: February 18, 2013, 01:48:05 pm » |
viceversa impostando ATmega328 1 Mhz e " caricando con un programmatore da questo messagig o
Dimensione del file binario dello sketch: 1.094 bytes (su un massimo di 32.768 bytes) avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check. _---------------------------------------------------------------------
cliccando sul pulsante " CARICA " da qust'altro messagigo
Dimensione del file binario dello sketch: 1.094 bytes (su un massimo di 32.768 bytes) avrdude: stk500_getsync(): not in sync: resp=0x00
Logged
Lamezia Terme
Offline
Shannon Member
« Reply #69 on: February 18, 2013, 02:24:11 pm » |
A me pare di capire che tu abbia una gran confusione in testa e ti stia muovendo a tentoni e senza alcun filo logico, se ancora non hai chiara la differenza tra la programmazione ISP e quella seriale, andando avanti in questo modo si rischia soltanto di riempire pagine di post senza senso, esattamente come gli ultimi due che hai scritto. Il problema è che deve metterti l'animo in pace e leggere SERIAMENTE la mia Guida, la prova che tu non lo abbia fatto sono gli errori delle boards virtuali, infatti hai tentato di usare quelle della versione 0022 invece di quelle specifiche per la 1.0.x, eppure io questa cosa l'ho ben specificata nella guida. Quindi, per quanto mi riguarda, insisto sul fatto che tu ti debba leggere bene le istruzioni e vedrai che alla fine ce la farai da solo, come succede al 99% di coloro che si cimentano in queste operazioni, poi l'eventuale problemino si risolve col nostro aiuto, ma così com'è per me non ne usciamo, a meno che non ci mettiamo noi l'animo in pace e cominciamo a guidarti passo passo, iniziando daccapo e cioè fornendoti le istruzioni iniziali e verificando ogni passaggio, però mi pare uno spreco di tempo che si può dedicare ad altro, proprio perché tutte queste info non hai che da leggerle.
Logged
Latina
Offline
Jr. Member
« Reply #70 on: February 18, 2013, 02:42:00 pm » |
ringrazio .
tentero '
Logged
Latina
Offline
Jr. Member
« Reply #71 on: February 18, 2013, 03:22:49 pm » |
ho letto tutta la sezione della parte stand alone . non ho tralasciato nulla .
non so cosa altro potrebbe essere .
Logged
Forum Moderator
Italy
Offline
Brattain Member
« Reply #72 on: February 18, 2013, 04:43:25 pm » |
Quando ti dice di controllare le connessioni... spesso succede di aver invertito un paio di fili, oppure di averli collegati male. O, ancora, di non aver messo il quarzo esterno quando serve. Insomma, in poche parole: avrdude non sta comunicando con il chip esterno. La firma digitale è la prima cosa che controlla, per verificare che il chip da programmare sia del tipo richiesto. Se avrdude non riesce a leggere la firma, vuol dire che non riesce proprio a comunicare con il chip.
Logged
Latina
Offline
Jr. Member
« Reply #73 on: March 04, 2013, 03:34:19 pm » |
buona sera a tutti ho riacquistato nuovo il atmega328 pu siamo sempre alle solite
cmq adesso da solo questo messaggio .
tutto il resto e corretto , collegamenti MOSI MISO SCK SS + la Vcc 5V
Logged
Lamezia Terme
Offline
Shannon Member
« Reply #74 on: March 04, 2013, 06:40:29 pm » |
ma hai preso il modello "P" o quello non P?
Logged
